Ryzen 3 Fan Curve
Mercuryaces
Can anyone recommend a cpu fan curve for the Ryzen 3 1300x? I’m looking for quiet, but to keep it cool under load.
just tinker with it.
set it to somewhere in the middle, and if it's too loud, lower speeds -- conversely, if it's too hot, increase speeds.
there's no perfect fan curve, you have to experiment and see what's right for you.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
