HEVC video in MS Edge not working
Solved by Tabs,
Does the store page for the HEVC decoder show you actually have it installed or not? I clean installed 16299.15 on my machine, so I didn't have HEVC installed and had to get it from the store, but my partner upgraded to it (originally from 10240 way back in 2015) and had it already.
The link is here, click it and then see if Store opens saying "Launch" or "Install". If it says "Install", then you need to install it, and restart all Edge processes.
