Search In
  • More options...
Find results that contain...
Find results in...
Compatible to mine(anything)? Mining setup(planning)
Just wanna make sure that my components will fit together for a mining rig:
Intel Celeron 3900t
MSI H110 PC MATE
8gb DDR4 2400Mhz memory
60gb SSD
1000W EVGA platinum PSU
2x R9 390 8GB (these i have)
2x rx 470 4gb  / 2x GTX 970 4gb / something else with similar wattage (480, 570, 1060, 1070)
4x 1x - 16x usb riser
stock cooler + 2/fans
PSU calculator says 880W under full load so 1000W should be fine.
Will this setup fit together?
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
check to make sure that MB doesn't throw a shit conniption when you install more than 3 GPUs.
some MBs do.
as for the GPUs and power draw, i highly recommend tuning them for best efficiency, not raw output.
never too late to mine cryptocurrency.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
1 minute ago, VenomZ_ said:
you should be fine. but ur kinda late to the party dont u think
yeaaaaaaaaaaah, but late then never :) still 5/6 months to get my investment back ( if i get it back) is fine with me (i can wait). And got the parts for a nice price.
some MBs do.
From my searches there are people using it with 4x gpus.
careful with ROI. IT's not linear and when dealing with Alt-coins, when BTC goes up, the value of alts generally goes down. If you're going to mine an Alt, i highly recommend doing so as a long term investment, not day to day cash.
System specs:
my initial goal is to go for the longterm. Since cryptos have a trend to go up in value, meaning my plan to sell them is when i reach the point when my investment will be paid (if ever) + i like to build PCs :) of any sort.
My first experiences were with nicehash( not real mining, well not mining at all :) ). With this rig i wanted to go for eth/altcoin but first i wanted to get some knowledge on configs etc, so i might play a few days with that at the start.
Take a look at the board first, you'll need a splitter since it only has 3 PCIe slots.
Ignore me, I saw the wrong board :)
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
It has 1x Pcie 3x 1x Pcie 2x and 2x Pcie 1x so i think i am fine right? :)
See my edit, I saw the wrong board so you're fine in that regards :)
Prior Build Log/PC:
Great, so i managed to get 2x 570 4gb for a great price, so my mining cards will be 2x 390 8gb and 2x 570 4gb. The 570 are the same ones, but the 390s are different one is Strix the other is Nitro, will that make some issues?
nope. has no bearing other than out of the box oc's, which if you were a smart miner, you would undervolt them to get the best hash/w possible for your selected algorithm.
System specs:
390 strix is already undervolted and memory OCed for equihash ( i think, that was what i found out works) and because of temps + power consumption, fan curve also set to go for the most silent operation. The rx 570 will arive friday. So i have to do the same with them.
go for cooling over silence if you can help it. A mining rig should be headless, and out of sight anyway. use RDP to manage it if you can.
System specs:
RDP is the plan, i am planning to put it outside and since the winter is now coming in my country the cooling should be fine. (humidity buildup already solved, airflow too, waterproofing/dust proofing and resistance against natural causes also solved, planing to put it into a box with filtered fan holes+fans, under roof so no rain, humidity buildup will be solved by dehumidifier(a good one)) Power cable will go to the rig and internet will go through wifi.
Dumb or smart?
i would still run the fans at 100%, but everything else sounds good. not too dissimilar from my own set up, though i am using 1070's.
System specs:
The fans, especially on the strix are so f-ing loud that it's unbelievable. I have a 1070 in my personal rig, mining with that too when I am not using the pc or just watching movies/Internet browsing. And it's water-cooled, super oced and Max temps are 42*C in a room that is 22*C :D I am kind of proud about that!
200mhz on the clock and 750 on the memory oc.
Thanks man for the help, if I my ask how much do you mine per month? And is it too naive to think that I will get my money back in about 6 months? (electricity is veeeeeery cheap where I live)
At about 2 weeks into my 3x1070 1x1080ti setup, i've got 7 ZenCash pool mining at zhash.pro with EWBF's miner.
zen is at 19.85USD at the current moment, so rough estimate i've made $120, but in reality it's less thanks largely to the high network fees of Bitcoin. it just doesn't pay to withdraw to Fiat until you've amassed a lot of coin, otherwise you're just socked with fees. hell right now i don't have enough BTC to even initiate a transfer because the network fees are higher than my balance...
System specs:
 Share
