First Time Build Advice - Under $1000
22 minutes ago, SOcean said:
Pretty much just fixed everything, if you're overclocking add a Hyper T4 or Cryorig H5 and put a fan on the VRM
also got a case with airflow, possibly just add an SSD later, The firecuda drive seems like a decent stop gap.
RX 580 for free-sync savings whenever the monitor upgrade comes.
If the current monitors are 1080p 60hz there's not much reason to go past a 580
MSI AM4 boards suck, and VRM kinda suck until you get to the ASrock Killer or ASUS Prime Pro
PCPartPicker part list: https://pcpartpicker.com/list/dvsDBP
Price breakdown by merchant: https://pcpartpicker.com/list/dvsDBP/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($189.99 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($74.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Newegg)
Storage: Seagate - FireCuda 2TB 3.5" 7200RPM Hybrid Internal Hard Drive ($99.88 @ OutletPC)
Video Card: MSI - Radeon RX 580 4GB ARMOR OC Video Card ($254.98 @ Newegg)
Case: Cooler Master - MasterBox 5 (Black) ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ SuperBiiz)
Total: $914.31
Generated by PCPartPicker 2017-11-19 23:04 EST-0500
