Search In
  • More options...
Find results that contain...
Find results in...
How much GPU power do you need for a 4K 144Hz monitor?
The title is probably a bit confusing (I mean, if you want to play AA-AAA games on high-ultra settings with good performance on such a display, what kind of/how much graphics cards would you need?)
And no, I'm not going to buy or try one, it's just plain curiosity (after seeing Predator X27 and PG27UQ)...
I was thinking about Quadro P6000, but what about GeForce or Vega cards?
quad 1080TIs or Titan Xp setups are my first thought
I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally)...
Builds:
There isn't really enough GPU power on the market to do this. We still don't have a card that can reliably max games on 4K - the 1080Ti and TitanXp still have issues with many games at 4K.
My 1080Ti even doesn't fare so well at 1440p. There's many games I can't even hit 100FPS on.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Be Quiet! Dark Base 700
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
Laptop
Model: MSI GE72MVR 7RG
CPU: I7 7700HQ
GPU: GTX 1070 8GB
RAM: 16GB 2400MHZ DDR4
SSD: 256GB Samsung NVME SSD
HDD: 1TB 7200RPM
Screen: 120HZ IPS Panel
Too much.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
One of my friends is buying one as soon as it's released. He currently has a 1080, might upgrade to a 1080Ti, but he's getting it more for the (dare I say it) "future proof" aspect of it. You won't need a monitor for a really, really long time.
As for you question, loads. I'd want at least 1080Ti SLI, but really if you're paying the rumored $2,200 for the monitor, it's not unreasonable to think you'd also have a system like that.
Current PC:
OG Gaming Rig - Gone
A LOT of graphics card. I dont think even a 1080ti SLI setup can keep up at all times.
It also seems that Volta wont come in gaming flavour as Ampere got revealed before Volta gaming cards (probably those tensor cores dont do well in games so performance gain is rather small). This means more time to wait till there's a card that can handle 4K 144Hz in AAA games with high graphics settings. At this point of time a 4K 144Hz display is only good for esports games, though they are good ones in that aspect.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
If you mean to hit 144FPS at 4K in the newest games at ultra, no setup currently exists to be able to do this and probably wont for some time. Thing is though you don't need to match the refresh rate of your monitor for it to be worth it, 60FPS/144Hz is a lot better than 60FPS/60Hz simply due to less tearing and input lag.
There are no GPU's on the market right now to get this kind of performance reliably across the board. 1440p 144hz in all games isn't really doable either. gonna have to wait a generation or two at least before you can see that kind of performance... or gonna have to tweak a lot of graphical settings.
lol. just stop m8. Nothing about what you just said here makes any sense. 60fps 144hz creates tearing, not reduces it. and there is no input lag difference between a 144hz monitor and a 60hz monitor if they're both running at 60 fps. You're still getting 60 fps and the frames still appear 16.7ms apart.
The higher the refresh rate of the monitor, the faster the most recent frame takes up the majority of the screen, making the tear less visible. For a vertical tear to be removed you need the monitor to refresh again before a new frame is received by the monitor, can you explain how a higher refresh rate makes this process slower, and thus makes tearing worse?
Further, can you explain how a monitor refreshing faster, and thus showing you the most recent frame drawn by the GPU faster, makes no difference for input lag?
You are wrong on both fronts, it's as simple as that.
60fps at 60hz results in no tearing. the monitor displays 1 frame per time it refreshes its image. Everything is synchronized. 60fps at 144hz does not do this. There will be times when the monitor refreshes its image, and there will be two separate frames on screen, resulting in a tear. If you had a higher framerate to accompany the higher refresh rate, the distance between tears would be less, making them less noticeable to the naked eye (even though they would be more frequent) so that is good to note, but none of this is better than non-existent tearing which is what you get with 60fps/60hz.
because 60 fps is 60 fps. in a 60 fps situation, your GPU will update the image and send it to your monitor every 16.67ms. if your monitor is a 60hz monitor, it will update every 16.67 ms as well, resulting in no lost time. if you have a 144hz monitor, a new image will begin being drawn every 16.67ms, regardless of whether or not the monitor is mid refresh (resulting in a tear, but it still updates 16.67 ms after the GPU sent the last frame), resulting in no lost time. No lost time in either situation means the difference between 60hz and 144hz does not change input lag.
So yes, I CAN explain it.
Can you just take five seconds to go and try this yourself so you can prove yourself wrong?
This doesn't happen though because the GPU and monitor aren't synchronized, monitors update at a fixed rate while GPU's draw frames at a variable rate, why do you think VSYNC exists?
Lets use an exaggerated example to prove you even further wrong. Say you are rendering at 1FPS on a 1Hz monitor, that means the monitor is only refreshing one time every second. Lets say the monitor refreshes, but 3ms after that the GPU draws another frame, meaning you now have to wait another 997ms for the monitor to refresh. Now lets say you are rendering at 1FPS on a 240Hz monitor, the monitor refreshes, but 3ms later the GPU draws another frame and you have to wait another 1.16ms for the monitor to refresh.
Milliseconds are a measure of time, 997 is a bigger number than 1.16, is this starting to make sense to you why a higher refresh rate means less input lag? I don't know why this is even an argument, assuming you have a high refresh rate display, just cap a game at 60FPS with no VSYNC and try it yourself at 60Hz compared to 120/144Hz.
You need an i7 8700k at 5.3ghz with Quadro P6000 OC'ed in 2way SLI, RAM should be at 3200mhzCL14 (32gb).
Workstation Rig:
CPU:  Intel Core i9 9900K @5.0ghz  |~| Cooling: beQuiet! Dark Rock 4 |~|  MOBO: Asus Z390M ROG Maximus XI GENE |~| RAM: 32gb 3333mhz CL15 G.Skill Trident Z RGB |~| GPU: nVidia TITAN V  |~| PSU: beQuiet! Dark Power Pro 11 80Plus Platinum  |~| Boot: Intel 660p 2TB NVMe |~| Storage: 2X4TB HDD 7200rpm Seagate Iron Wolf + 2X2TB SSD SanDisk Ultra |~| Case: Cooler Master Case Pro 3 |~| Display: Acer Predator X34 3440x1440p100hz |~| OS: Windows 10 Pro.
Personal Use Rig:
CPU: Intel Core i9 9900 @4.75ghz |~| Cooling: beQuiet! Shadow Rock Slim |~| MOBO: Gigabyte Z390M Gaming mATX|~| RAM: 16gb DDR4 3400mhzCL15 Viper Steel |~| GPU: nVidia Founders Edition RTX 2080 Ti |~| PSU: beQuiet! Straight Power 11 80Plus Gold  |~|  Boot:  Intel 660p 2TB NVMe |~| Storage: 2x2TB SanDisk SSD Ultra 3D |~| Case: Cooler Master Case Pro 3 |~| Display: Viotek GN34CB 3440x1440p100hz |~| OS: Windows 10 Pro.
HTPC / "Console of the house":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
9 hours ago, Cookybiscuit said:
Snip
well alright then. It doesn't matter if you understand why you're wrong or not. at the end of the day this is not what this thread is about. I will not entertain your ignorance any further and this thread can return to its original topic.
This setup will not yield the desired level of performance. Sure its probably the best thing you could possibly hope for on the market today, but its still not enough horsepower (especially on the GPU side of things) to fuel a variety of games at his requested settings and resolution/refresh rate.
We don't have anything yet (consumer level at least) that will. Good thing those 144hz panels have g sync :) I can't wait to get the pg27uq
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
A 1080Ti is there or thereabouts for 4K/60 at ultra (minor settings changes perhaps). To go from 60 to 144 or even 100 is a huge leap. Let’s face it,  a single card won’t be able to do that for at least 3 years. Which means once 4K/144 monitors are more commonplace and kind of affordable, SLI will then be more fashionable (right now everyone and their dog are complaining that SLI is crap). Which should mean that SLI support from nvidia and amd, and the developers, will improve.
Thats my hope anyway.
Love not hate
Damn you got me, you proved all of my points to be incorrect, what a fool I look,
Congratulations, you win this argument.
Multi-GPU support COULD improve going forward, but not in the traditional "SLI" (or Crossfire) sense. From my understanding, SLI is on its way out. LDA/MDA is what most people have been talking about since the Pascal SLI adjustments, but rumor has it that Nvidia is working on another technology to directly replace the aging SLI standard. In any case, you can bet that these new technologies (whether it be the generic LDA/MDA or whatever Nvidia/AMD has up their sleeves) will require it to be up to individual developers to properly code and implement into their games/engines and whatnot in order for these features to work at all... which is unfortunate, because few developers are going to go out of their way and spend extra money on something which otherwise won't really help their game sell all that much better. If there is no ROI for a company to spend the time and money on doing something, there is a very good chance they just won't do it.
So I too hope for a multi-GPU future, but I just don't see it happening. But then again I didn't see the 1070ti happening, so who knows what kind of crazy stuff they'll think of next ;)
I don't have a 4K/144Hz panel (yet).  However, I've been doing some experimentation with BF1 recently.  My settings are custom: 1440p, maxed out everything except AA and ambient occlusion (both disabled).  My rig is able to hold 142FPS, where I have it locked in the NVidia driver, pretty easily on most maps.
For giggles, I set the scaling to 150%, which is equivalent to 4K.  I saw the load on my GPUs almost double (not quite), but I maintained my basic 142FPS on most maps.
I'm using 2 Titan X Pascals (the gimped ones, not the Xp), which have been OC'd +200 core/+500 memory.  This works exceptionally well in titles like BF1 because Frostbite does SLI so fricken well.  Other titles might not.
Editing Rig: Mac Pro 7,1
System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro Vega II (32GB HBM2) | Lots of SSD and NVMe storage |
Audio: Sound Blaster X7 external DAC/ADC |
Gaming Rig: PC
System Specs:  Asus Rampage VI Extreme board | Intel Core i9 7900X | 64GB Corsair Vengeance LPX (OC'd to 4GHz) | 2 x NVidia 2080Ti FE cards (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) |
Audio:  Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic |
Displays: Asus PG27UQ 4K/144Hz display | 2 x LG 27UK650-W 4K displays |
Cooling:  2 x EK 140 Revo D5 Pump/Res | EK Asus R6E monoblock | 2 x EK 2080Ti waterblocks | 2 x AlphaCool 480mm x 60mm rads | AlphaCool 560mm x 60mm rad | 21 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers |
more than what will be available during the next few years. I mean you can play them at 4K/100~ish Hz  smooth but with lowering all the rest of the quality of the game, making the title not really AA/AAA anymore.
