Search In
  • More options...
Find results that contain...
Find results in...
Razer Blade Stealth + Core for VR?
krkevin
 Share
Hi, I was wondering if I could connect a Razer Blade Stealth with the Razer core and possibly play VR such as Oculus Rift. This is because I want a new laptop right now, but am thinking of buying a Razer Core and Rift later when I am ready and VR has advanced well.
Thanks.
-Kevin-
You can get the Core with any laptop that uses TB3.
Edit: What's your max budget and location?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
You don't currently have a Blade Stealth, then? I've heard a lot of reviews saying they have really bad thermals. I personally would go for a laptop from Asus, Acer, or MSI with a GTX 1060 6Gb or a 1070 over a Razer
If my post solved your problem/answered your question, please consider marking it as "solved"
Community Standards // PSU Tier List // Bugs and Issues // Join Floatplane! // Join the LTT Official Discord //
Max budget is $2000 CAD. I live in BC, Canada.
Of course it would have bad thermals if they're trying to cram so much stuff into a thin chassis. What laptop would you recommend then? I'm also fine with buying a desktop if that's cheaper.
-Kevin-
At your budget, probably this one: https://www.amazon.com/MSI-GS63VR-Stealth-Pro-230-i7-7700HQ/dp/B01N5JUPWO/ref=sr_1_6?ie=UTF8&qid=1509940046&sr=8-6&keywords=msi+stealth+laptop
NOTE: the price on Amazon is in USD, not CAD
the core is one of the first and therefore most unstable and badly engineered docks out there.
for good vr, id recommend a 1070 - the gigabyte box comes with one for $599usd which is super cheap.m
blade stealth will bottleneck a 1070 tho, even with 8th gen.
normal blade might struggle, wait for 8th gen
If I helped, hit the thumbs up icon below my post and pick it as 'Best Answer'
Resident living meme - I swear a lot; if you don't like it fuck off :^)
  My specs and shit down below.
Apollo: i5 4670K @ 4.6Ghz, Corsair H100i, MSI Z87I, EVGA GTX 1070 SC ACX3, Corsair 250D, 840 EVO 120GB, 1TB Seagate Barracuda, SeaSonic 520W PSU. Planned upgrades: 16GB RAM, 480/512GB SSD, new HDD
Sputnik: HP EliteBook 2570p, i5-3360M, 16GB DDR3, 256GB 840 EVO - Running Win10/Sierra dual-boot.  Future upgrades: i7-quad
Comet (home server): Atom D2500, 4GB 1066Mhz RAM, 2 x 320GB HDDs, 350W PSU, HAF-Stacker ITX, dual GbE. Cost me $80. back from the dead (mobo failure) bois
Main peripherals
- Corsair Strafe RGB MX Reds
- SteelSeries Siberia 650
- SteelSeries QcK+ CS:GO Camo
- SteelSeries QcK+ Na'Vi Splash (Secondary pad, used for second rig)
- SteelSeries Rival 700
- SteelSeries Rival 300 (Secondary mouse, used for second rig)
The Core is the first of its kind, but it isn't the first GPU dock. By a LONG shot, docks have been available since Express cards were "in style" and I even got one in the late-2000's (worst idea ever with a uni-core laptop).
Eurocomm has 2 laptops with a 7700HQ + GTX 1070 for CAD $1919 no OS, 1 tb HDD.  Get win10 on ebay for 15 bucks (working well for me :P
More powerful, with more storage options
http://www.eurocom.com/ec/configure(2,405,0)SkyMX5R3
Larger screen with a Max-Q GPU (slightly less powerful)
http://www.eurocom.com/ec/configure(2,422,0)EurocomQ5
Want to custom loop?  Ask me more if you are curious
47 minutes ago, Crunchy Dragon said:
It's above $2000 when converted to CAD, so no thanks.
Is Eurocomm a reliable company?
-Kevin-
Yep, I own an ExpressCard eGPU.
However, the core is based on an older TI 82 chipset, where the newer docks are based on the TI 83, which has better support for newer TB3 chipset revisions and better support for OSes that aren't Windows. Core V2 is coming soon with TI83.
Main peripherals
Super reliable, they actually have several showrooms in Canada
Eurocom uses Clevo bases, am I right?
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Station (Intel-powered Lenovo Yoga Slim 7i)
CPU: Intel Core i5 1135G7 | GPU: Intel Iris Xe 80CU | RAM: 16GB LPDDR4X-4267 | Storage: 512GB PCIe SSD | OS: Microsoft Windows 10 Home
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
Maybe not with all of their pcs but at least a few do
 Share
