Cooling Combo Confliction
Solved by LogicalDrm,
3 minutes ago, Mike Soda said:Wow really? I'd like to have one fan pushing air into the 1st set of fins on the right with the second fan in the middle pushing/pulling out the last set of fins on the left, that combo is possible?
Thats how its by default. Here's pic where 1st fan is raised. Which is option as your case has 190mm clearance. Meading that fans top can be 30mm higher than heatsinks top.
Other options with that fan setup is to use 120mm fan as first fan. U14S is good alternative with bit less cooling performance.
