Search In
  • More options...
Find results that contain...
Find results in...
[Build log - Completed build] Camouflaged Gold - Custom loop with Brass tubing - Fractal Design Define Mini C TG
teflontanten
 Share
Camouflaged Gold
First of all, this build was finished a few days ago. I wasnt planing on doing a build log but I did take some bad quality photos during the build process with my phone that I thought I could share with you. Further down you can find better quality pictures of the finished build.
I felt it was time for a new build!
This time i chose a colorscheme that is a bit unusual. I got the idea when i stumbled over Bitspower new brass tubing.
This time I decided to go with Fractal Designs Define Mini C TG. A very nice case with a glass side panel and room for a mATX motherboard.
A lot of work is done with acrylic, in gold and transparent colours, that is cut to size and then dressed in vinyl. After that I cut out a few patterns in them with a scalpel, that way exposing the gold. I also added a small display to monitor the water temperature in the loop.
If you want to see a sneak peak of the completed build you can do that here
Please feel free to leave a comment!
These components were used in the build:
Computer:
Case: Fractal Design Define Mini C TG
PSU: EVGA SuperNOVA 650 G2
MB: Asus Z270G Gaming
CPU: Intel i5 7600k
GPU: MSI Geforce GTX 980
RAM: Corsair Vengeance LPX 16GB DDR4
SSD: Samsung SSD 960 EVO 500 GB NVMe M.2
Fans: 4x Fractal Design Venturi HP-12 PWM 120mm
Lighting :2x Nanoxia RGB Rigid LED bar - connected to and synced with the motherboard.
Cooling:
CPU: XSPC RayStorm Pro WaterBlock - Intel - Black
GPU: EK-FC980 GTX - Acetal + backplate
Pump: EK-XTOP DDC 3.2 PWM Elite - Acetal
Res: Bitspower Water Tank Z-Multi 150 - True Brass
Radiators: 2x EK-CoolStream SE 240 (Slim Dual)
Fittings: Bitspower True Brass
Tubing: Bitspower Brass tubing
The disassembled case and the motherboard.
Cutting out some of the first acrylic panels.
Trying out different lengths of the reservoir. In the end this turned out to be to long.
This 150 mm one was a better fit.
Cut out a few more acrylic panels. :-)
The front panel of the case is clean. And a bit booring. I decided to do something about that.
This is the front panel after i dressed it in a metallic gold vinyl, and then a camouflage vinyl over that. After that I cut out a tree shape with a scalpel.
Expanded a hole in the case near the top to be able to mount a pass through fitting later.
Just testfitting the motherboard with CPU-block before proceeding.
That spoiler photo tho..... That case looks amazing, truly
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX550M    Cooling Cryorig H7 with NF-A12x25
Made a acrylic plate to mount the pump on under the PSU shroud.
This is how the pump is mounted in the lower compartemnt.
The acrylic midplate dressed in vinyl with the reservoir mounted.
An other angle.
Testmounting in the case.
The outer layer of the CPU-block covered in vinyl to fit the rest of the build.
My cats.
Testmounting some of the panels...
... And the radiator.
Closeup of the pass throughs to the lower compartment.
Testing how things fit.
Some Bitspower fittings.
Thinking about how to run the loop.
Thats better!
Decided to redo some of the panels using this mirror gold acrylic.
Dressed it in vinyl, draw some patterns and then cut it out using a scalpel.
Result.
Did the same with the panels that cover the radiators.
Now we are getting close.
Leak testing. No leaks!
Thats all the photos i took during the build process.
5 hours ago, teflontanten said:
Here are some better quality photos of the end result!
Hope you enjoy!
--SNIP--
What a beautiful piece of art! Gold rated!
CPU: i7-5820k @ 4.2Ghz // MOBO: Asus X99 Sabertooth // RAM: 32GB Corsair Dominator Platinum 2400MHz
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: Samsung Evo 850 500GB + 250GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
Well this is all kinds of awesome.
I don't exactly agree with some of the component choices, but the aesthetics are absolutely top notch. Kudos to you, sir.
Side note, you should submit this here:
http://www.fractal-design.com/home/product/case-modding
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
4 hours ago, Limecat86 said:
What a beautiful peace of art! Gold rated!
Thank you guys! :-)
Regarding the components, I was on a somewhat tight budget, so the top end hardware have to wait a bit.
I actually sent them an email a few days ago with a description of the build and a link to an imgur album containing the pictures. So far I dont think they have looked at it though.
I am not a fan of gold.
But this has truly opened my eyes! I love the handy work you did as well! Definitely a gold-star rating :D.
Holy Shit omg... I absolutely love the looks of golden brass! Been wanting to do a build like this for a long time and you have basically made what is right now a dream for me :P Just stunning!
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
That's some top bling, mang.
Also, we require at least 5 more cat pictures.
I deal in shitposts and shitpost accessories.
Thanks man! Much appreciated. :)
Thank you! You should really try it, the brass tubing and Bitspower fittings is very nice to work with! :)
Thanks! I will see what I can do about the cat pictures. :D
RAINBOWS!!!
On 2017-11-03 at 2:52 AM, 8uhbbhu8 said:
As requested here are a few more photos of my cats (I put them in the spoiler). Enjoy.
WOOOW that is so beautiful that build, love the army and gold combo theme :-), cute cats also :-)
Thank you! I´m Glad it´s appreciated! :-)
 Share
