my monitor
IAlwaysneedhelp
so i have two monitors Right now but  my windows 10 wont see it
one is dvi for my gpu and one is vga just pluged into the port that comes with the pc
If your motherboard/CPU doesn't come with integrated graphics, you won't get any video from that port.
how do i know if it has intergrated graphics
what cpu, motherboard do you have?
cpu is a ryzen 3 1200
and mother board is gigabyte dont know extact model
no, you don't have integrated graphics
So plug both monitors into discreet gpu?
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
theres only one port
Whats your graphics card?
Quote
Quote
Quote
Quote
Well the rx460 is your discreet graphics card and it has a DP, HDMI, and DVI port.
You can plug both monitors into that yes?
Quote
Quote
Quote
Quote
He mentioned that the other monitor is VGA (D-Sub) so he will need an active adapter for DP to D-Sub.
Yup, I was waiting for that.xD
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=hdmi+to+vga+adapter
Quote
Quote
Quote
Quote
8 minutes ago, Iamialwayneedgelp said:
So see the metal bar that's blocking tr hdmi from going in fully
Yes, I do see that metal bar.
I think you just hijacked someone else's post.xD
The male HDMI plug your trying to put in there is most likely made of soft plastic which you might be able to cut a small notch in so it fits over the metal bar.
Quote
Quote
Quote
Quote
kk thanks
do you know what type of hdmis that will fit that is not soft plastic
I'm not sure what you mean.
You said your HDMI plug would not fit in the graphics card because of the metal bar.
I suggested cutting the soft plastic on the HDMI plug that was hitting the bar so the plug would go in.
Quote
Quote
Quote
Quote
the plug is metal, but the plug is surrounded by plastic. don't cut the connector itself, just the rubber around it on the top.
