Search In
  • More options...
Find results that contain...
Find results in...
Will an i7-2600 bottleneck a GTX 1060?
Go to solution Solved by Trulop,
it shouldnt. IPC is similar to the G4560 and Jayz2Cents did a video showing that bottlenecking doesnt occur until the GTX 1080TI ranges, and the 2600 has more cores and threads which helps other multitasking workloads and maybe some games that can take a bit more advantage of the extra cores/threads.
2 minutes ago, Crunchy Dragon said:
It's been said to not get the 3Gb version of the 1060(I forget why though). I don't see too much reason for either one to bottleneck the other
the 6gb version is a refresh, and has more power as well as more VRAM, making it sorta like a 1060 TI. 1280 vs 1152 cores i believe.
Will a GTX 1060 6GB bottleneck my i7-2600 non k processor? If so, is it better to get the 3GB version in this case?
If my post solved your problem/answered your question, please consider marking it as "solved"
Community Standards // PSU Tier List // Bugs and Issues // Join Floatplane! // Join the LTT Official Discord //
I can see that a 1080 Ti won’t bottleneck in like 4K or 2.5K res, but what if I would run a GTX 1060 to get 144FPS on low settings in games like Rainbow Six Siege or COD WW2. Would my i7 still not bottleneck it? (Because I would want to run very high framerates).
Sorry if this question is dumb.
Don't worry about bottlenecks... the word itself has become overused. The i7-2600 and GTX 1060 6GB are a good pairing.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
We don't know how CoD:WWII will perform yet since we've only seen a beta.
R6S runs at 130Hz minimums on my i5-4690K, so your i7 should be able to get 144Hz relatively easily with a few settings lowered (possibly high to very high).
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I run my 2600k at stock speeds and I dont feel like it's limiting my 1070 at all.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
The 6GB was the original. The 3GB was released a few months later, IIRC.
I still think they should have made the 3GB into the 1050 Ti with 4GB of VRAM.
Ryzen 5’s single core performance is 49% faster than i7-2600’s, and Ryzen 5 is ALREADY worse than new core CPU’s. So you know, just wanted to be sure I wouldn’t miss-purchase if that’s a word.
That brings me confidence, thanks.
Maybe I’m stupid after all.
Citation needed. It depends on the clockspeed of both processor but the single threaded performance between those two CPUs is not that large... 49% is an exaggerated number.
The i7-2600 still holds itself up very well.
Just now, HKZeroFive said:
The i7-2600 still holds itself very well.
Yeah I believe that actually.
not in the slightess, and get a 6GB card.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
1. no it wont bottleneck
2. vram does not affect bottlenecks between the cpu and gpu
GTX 1060 6GB as 11% more cuda cores, and twice the VRAM...it's well worth the little extra $ in most countries if you play modern games.
No. 6GB version came first, then a stripped-down 3GB version came. I know, I bought a 6GB model on launch day (I know, stupid decision).
Current LTT F@H Rank: 85    Score: 1,206,444,324    Stats
My main Rig (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (Kernel 5.10.7 VFIO) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.8.3
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
https://www.kitguru.net/components/graphic-cards/matthew-wilson/asus-to-refresh-gtx-1080-and-gtx-1060-with-faster-memory/
the 1060 6gb was refreshed. the 3gb version was also reduced to 1152 cores a while before this refresh though and the price was dropped a bit to better compete with the pricing of radeon cards. Both are correct.
Well I was completely unaware of that. I apologize.
PSU: EVGA G2 650W
OS: unRAID 6.8.3
PSU: EVGA G3 850W
 Share
