First ever made Build for 1440p Gaming
Cadiz
Hello first of all if you spot any typos or gramma issues within this text please dont mind it, english isnt my native language.
To the Build.
I want to use it mostly for Gaming on Max settings and in WQHD. My budget is 2000€
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler:  Enermax - Liqmax II 120 96.0 CFM Liquid CPU Cooler
Mainboard: Asus - STRIX Z270F ATX LGA1151 Motherboard
GPU: Zotac - GeForce GTX 1080 Ti 11GB Mini Video Card
Memory:  Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
Storage:  1x SSD (Updated) Samsung MZ-75E500B/EU 850 EVO 500gb1x HDD Toshiba - Product Series:DT01ACA 2TB 3.5" 7200RPM Internal Hard Drive
Case: Game Max - FALCON WHITE RGB ATX Mid Tower Case
PSU: (Updated) Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer
Monitor if it matters will be a   AOC AGON AG241QX 60,5cm (23,8 Zoll)144hz  2560x1440 and G-Sync
So my question is, is the PSU enough? And is there anything else you can see wich will be a problem?
Link to the Build https://pcpartpicker.com/list/TLg2XH
Many thanks to anyone who helps me out!!
Are you buying everything or have the 7700K and the 840 EVO already. If not switch it for an 8700K and the Z370 variant of that mobo. Also buy the 850 Evo instead. Faster cheaper and a lot newer
Main PC
i7 7820X @4.5Ghz/Asus X299 TUF Mark I/GSkill TridentZ RGB 4x8GB 3000MHz/MSI GTX980Ti Gaming 6G/960 Pro 512GB/850 Evo 500GB/2x2TB HDD/Enthoo Evolv TG/H115i w/HD140s/Corsair HX 850i
Other PCs
i7 3930K/16GB DDR3 1866Mhz/Big Bang Xpower II/MSI GTX 760 TF 2GB/BQ DP P8 1000W/850 Evo 250GB/2TB WD HDD
i5 6600K/BQ Dark Rock 3/16GB Vengeance LPX/ASUS Z170 Pro Gaming/Intel 120GB SSD/GTX 1060 Strix/1TB HDD/Corsair RM650
R5 1600/8GB Vengeance LPX 2666Mhz/ASUS B350F Strix Gaming/ GTX 1050Ti Strix/850 Evo 250GB/1TB HDD/BQ 530W
Notebook Lenovo Ideapad 710S 6500U/8GB/256GB NVMe
Peasant gaming stuff PS3/PS4 Pro/PSP/PS Vita
The PSU is really sketchy. Not due to the wattage, but the quality. Don't cheap out on the PSU.
Don't get the 7700K. Depending on what your use case is, get the 1700, 8600K or 8700/K.
The 840 Evo is really old. Is the 850 Evo or MX300 available?
Don't get a 120mm AiO. Either get a decent air cooler, or a 280mm AiO.
I allready have the i7 7700k here.
Will do that with the SSD thanks!
Any suggestions for the PSU?
Any suggestions for a good Air cooler?
Since it's a nice PC, something like the EVGA G2/G3, Seasonic Focus Plus Gold and Corsair RMx.
Or any tier 1 in the list.
Decent air coolers are the Cryorig H5 and H7, Dark Rock 3 and NH-U12S/14S.
OC3D has a big roundup, so choose one that gets decent temps.
https://overclock3d.net/reviews/cases_cooling/cpu_air_cooler_mega_test/39
Edited by seon123
Something something
i'll go for the Dark Rock 3.
Thanks everyone!!! With these suggestion my build should be complete and ready to go.
