5 long beeps on startup problem
Solved by Stalker_PY,
it is solved guys, it was a bad memory after all, today i went to the place where i bought the memory and they tested with another memory (same type) and it works perfectly now
so you know now, if you have 5 long beeps with your gigabyte motherboard it is problably the ram
thanks for all the answer
IhateAMDDRIVERS ·
Posted in Troubleshooting1 -
SashaSanguine ·
Posted in General Discussion3 -
3
Redsin ·
Posted in Graphics Cards2 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
2
1
3
2
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
