Search In
  • More options...
Find results that contain...
Find results in...
PLEASE HELP MY FREEZING PC
GAMINGGUY
 Share
Hi,
I recently got a TV to use as a monitor. When I started my PC plugged into the new TV the resolution was all messed up and all that junk. Went to the settings and changed everything to 4k like the TV. Then I decided to buy an actual monitor and put the TV somewhere else in the house. Now whenever I startup my PC on my old monitor it freezes after maybe a minute, all the audio stops, the mouse won't move, and basically after 30 seconds or so everything works fine.
Please help me
Thanks,
8 minutes ago, Spoderman!! said:
If it's cold you could perhaps put a blanket or two over it, to make sure it won't freeze.
Hopes this helps :)
Or perhaps a space heater.
In all seriousness, try to see if the old resolution from the TV is still in settings.
My Main PC Build:
CPU: Intel Core i5 2320 @ 3.00GHZ
GPU: Gigabyte GTX 1050 Ti Windforce OC 4GB @ 1.75 GHz
RAM: Ballistix Sport (1x8 GB) + Generic (2x2 GB)
Storage: Seagate FireCuda Gaming SSHD 1TB
Motherboard: Dell 0Y2MRG
PSU: CoolerMaster Elite Power 460
Case: Dell XPS 8300
Operating System: Windows 10 Pro 64-bit
Peripherals:
Display: ASUS VE278Q 27" Full HD 1920x1080 2ms
Keyboard: Logitech K120
Mouse: Zelotes T90 9200 DPI
Sound: Logitech H390 (Upgrading soon)
I also have a NAS server that I don't know the specs for.
Quote/reply to me so I get notified etc.
Message me for questions/concerns.
When I go to the settings it says 1920x1080 like its supposed to right, for a 1080p display?
what is your pc specs maybe its to low
I doubt it, I have a GTX 1080 turbo, i7 6700k, and 32 gigs of ddr4 ram. Is it possible that it's just a buggy update for windows or something?
That's what I'm thinking. Are you familiar with DDU?
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
All I know is that it means Driver Display Uninstaller. (I think o.O anyways)
Yeah. You can download it here. Run it and reinstall your video drivers and see if this fixes your issue. It's worked for me quite a few times now.
qυoтe мe pleaѕe!
Not saying that you sent me a virus or anything, but could I just go to NVIDIA and reinstall the latest update?
No, DDU completely removes the old driver, kind of "cleaning" it. Basically unfucks your GPU. Then you go to Nvidia's website and redownload the latest driver, GeForce experience, etc
qυoтe мe pleaѕe!
Oh, ok. Ill try it and let you know if it works. Thanks so much
Hi, I was going to go do DDU but there was an update for Windows. I downloaded it and everythings fixed. Thanks anyways!
 Share
