Search In
  • More options...
Find results that contain...
Find results in...
Suggestions for a tempered glass case
twisterfries
 Share
need help on finding a tempered glass case that is "AIO friendly" with good vents for airflow.
thank you
thank you
Fractal Design Meshify C, or Phanteks Enthoo Pro M TG
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX550M    Cooling Cryorig H7 with NF-A12x25
I think you're spoiled by choice really but the top 4 that comes to my mind:
- NZXT S340 Elite
- Phanteks P400 Tempered Glass
- Fractal Design Meshify C
- Corsair 460X.
They are many more but these are the best bang for the buck
I really love my Phanteks Enthoo evole TG case, and its pretty nice in my opinion with rgb and cable managment.
BUT the Airflow in it isn't the best, but doable, and i have a x62 Kraken that fits perfectly both up top and infront.
But however if the Define C TG came out a month earlier i would have bought that.
I've heard bad things about the Corsair X series' noise reduction, since all sides are tempered glass, there are notable gaps between all of the panels, effectively negating any noise reduction a normal case would offer.
The Define C TG or Pro M TG would be my suggestions
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
 Share
