Search In
  • More options...
Find results that contain...
Find results in...
What is exactly going on in my rig?
Go to solution Solved by Valkyrie Lenneth,
2 minutes ago, Pranesh Arry said:
So I am blocking it okay?
yeah why not xD i would even personally remove it if i were u xD better a program dead / broken that u can reinstall then some friggen malware right?
So, i left my computer in lock mode, but as soon as i entered my computer again, this is what my pc is showing, NPAV is my antivirus and it is blocking some stuff shall i allow it or it is a virus?
if u see what location that thing is in, it seems like either a virus or a fake call from ur AV however in ur case i wouldnt trust that shit unless u know that stuff is legit :P
Yeah, that's what i am asking, is it a system file or a virus?
it came from APPDATA it is not a system file
it is either from a program u have or a virus, im guessing its virus because the location of the thing is in appdata, and usually programs dont really launch stuff from there :v ( however some programs do )
also the name of the file seems rather fishy :S HfJNEzKu.exe ? rly xD
Looks like a virus, so blocking it would be a good idea, even deleting it.
Main PC: Acer IPISB-VR│Intel Core i7-2600s 2.8GHz│CoolerMaster CPU Cooler│16GB DDR3 1600MHz Dual-channel│AMD Radeon RX460 4GB│SanDisk Z410 120GB SSD + WD Blue 1TB 7200rpm + Seagate 1TB 7200rpm│Windows 7 Pro x64│CoolerMaster Silencio 352M│Seasonic M12II-520 EVO 520W│Acer SA220Q 22" 1920x1080
Secondary PC: MSI H81M-P33│Intel Core i7-4790 3.6GHz│DeepCool Ice Edge Mini FS V2│16GB DDR3 1866MHz (1600MHz) Dual-channel│AMD R9 270 2GB│WD Green 120GB SSD + Samsung 640GB│Windows 11 Pro│Acer Aspire M1930│CoolerMaster B500 v2 500W│Samsung S19B300 1366x768 & Fujitsu-Siemens P15-1 1024x768
Test PC: ASUS M2N│AMD Athlon64 x2 4600+ 2.4GHz│Stock AMD cooler from A8-7600│4GB DDR2 800MHz│nVidia GeForce 9500GT 1GB│Hitachi Deskstar 80GB 7200rpm + WD Raptor 74GB 10000 rpm│Windows 7 Pro x64 + Windows XP Pro SP3│TurboX Case│Zalman 450W│Samsung S22D300 1920x1080
HTPC: HP Elite 8200 USDT│Intel Core i3-2120 3.3GHz│6GB DDR3 1333MHz Dual-channel│Intel HD Graphics 2000│500GB 5400rpm│Windows 10 Pro x64│JVC LT-32VF30K 32" 1920x1080
Main laptop: HP EliteBook 8470p│Intel Core i7-3520M 2.9GHz│8GB DDR3 1600MHz Dual-channel│Intel HD4000 Graphics│WD Green 240GB SSD│Win 10 Pro x64│14.1" 1600x900
Secondary laptop: HP EliteBook 8470p│Intel Core i5-3320M 2.6GHz│8GB DDR3 1600MHz Dual-channel│Intel HD4000 Graphics│Kingston 240GB SSD│Win 7 Pro x64│14.1" 1600x900
Main phone: Sony Xperia X CompactOther phones: Sony Xperia L3, Sony Xperia Z3 Compact (x2){and both are dead now}, Sony Xperia E3, Sony Xperia Tipo + 12 more (not going not list everything)
All other PCs and laptops I own:
Small laptop: Acer Aspire One D255│Intel Atom N550 1.5GHz│2GB DDR3 1333MHz│Intel GMA3150 256MB│Western Digital 500GB 5400rpm KingDian S100 32GB SSD│Win 7 Ultimate x64 & Win 10 Pro x6410.1" 1024x600
Old secondary PC: ASUS A7V8X-X│AMD Sempron 3000+ 2.0GHz│Titan CPU Cooler│1.75GB DDR 400MHz│nVidia GeForce FX5700LE 256MB│2 x WesternDigital 40GB 7200rpm│Windows XP Pro SP3│Some case without sidepanel│Codegen 300XA 350W│Dell E173FP 17" 1280x1024 & Fujitsu-Siemens P15-1 1024x768Philips 200P4 20" 1600x1200
"The Old" PC: eMachines eTower 466i│Intel Celeron 466MHz│512MB RAM PC133│nVidia GeForce FX5200 128MB PCI│Seagate Baracuda 40GB 7200rpm│Windows 98SE & Windows XP Pro SP3│IBM P50 14" 1024x768 CRT
"The Floppy" laptop: Clevo 2700C│Intel Pentium III 1.1GHz│512MB PC133 SDRAM│SiS 630 32MB shared│Samsung 40GB│Windows XP Pro SP3│15" 1024x768
"The P4" laptop: HP Pavillion ZD8000│Intel Pentium 4 3.2GHz│2GB DDR2 666MHz Dual-channel│ATi Mobility Radeon X600 256MB│Seagate 100GB│Windows XP Pro SP3│17" 1440x900
Dell laptop: Dell Latitude D600│Intel Pentium M 1.6GHz│1.5GB DDR 333MHz│ATi Mobility Radeon 9000 64MB│40GB IDE│Windows XP Pro SP3│14.1"  1400x1050
Test PC for Win11: ASUS M4N68T-M-V2│AMD Athlon II x4 B40 3GHz│Some 130W tower cooler│4GB DDR3 1333MHz│AMD Radeon HD7470 2GB (with 80mm case fan)│WesternDigital Blue 250GB 7200rpm SATA II│Windows 11 Pro│Unknown Black and some silver case│FSP 350W│Samsung S22D300 1920x1080
Old Secondary PC: HP IPISB-CH│Intel Core i5-2320 3GHz│DeepCool Ice Edge Mini FS V2│8GB DDR3 1333MHz│AMD R9 270 2GB│WD Green 120GB SSD + WD Blue 1TB 2.5"│Windows 7 Ultimate x64│Acer Aspire M1930│CoolerMaster B500 v2 500W│Samsung S19B300 1366x768 & Fujitsu-Siemens P15-1 1024x768
HURRAH! ....... nothing happens...
Thanks for your time guys
The file and the file the AV is blocking are two different files, right?
Something not-good is happening in the background and you should probably run a malware scanner like malwarebytes to see if it digs up anything.
np man, just remember to browse girls irl rather then on redtube xD ( just kiddin lol ) tip to avoid getting more of these HfJNEzKu.exe thingies xD haha
Ok i will run hitman pro
Okay hitman pro did it...
thats quite a list u got there in ur registery ._.
with a list like that i would personally just format and get a clean install :v unless ur sure the trojan detections are programs u use legit, ( im pretty sure the one in the registery are malware/virus )
Kaspersky now has a free version of it's software. I'd run that, MalwareBytes, Norton NPE, and Panda CC, just to double check with other AV scans. Cannot ever be too cautious.
Also, another thing I've noticed is many programs now aren't being "installed". Instead you get an embedded .exe that has a Task Schedule associated with it, and that is how it executes. I would to into Task Scheduler and check to make sure you don't have anything you are unfamiliar with, in addition to checking your current list of installed programs.
As @Valkyrie Lenneth said, I agree that it may be time for a clean install. Also, using far more caution with downloads would be good. Fake updaters and AVs seem to be a trend there. If you are not the only one using the computer, I heavily recommend educating those that do. Social engineering is the biggest harm to a PC these days and no AV can stop that kind of human behavior outright.
 Share
