Search In
  • More options...
Find results that contain...
Find results in...
1080: Aorus or Zotac?
Gdourado
 Share
Hello, how are you?
Any advice on the Aorus 1080 11gps vs the 1080 amp extreme?
With both costing the same, which is the better card?
From what I can tell, almost all 1080s cap out at 2050 core give or take, so it might be a matter of which has the better cooling solution with regards to temperature and noise, but please correct me if I am wrong.
The Aorus:
https://www.gigabyte.com/Graphics-Card/GV-N1080AORUS-8GD-rev-10#kf
The Zotac:
https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1080-amp-extreme
Thank you.
Cheers
4 minutes ago, Gdourado said:
Monitor resolution/refresh rate and CPU?
The Zotac AMP Extreme managed to do less efficient power delivery than FE despite having a lot more phases... avoid it unless it isn't significantly cheaper.
Also, you have to do a mod to the card to fix the cooler. (The cooler doesn't make contact with the VRM where it should).
1080p 144hz 3770k at 4.6.
A 1070 or flashed Vega 56 would be fine for that monitor, 1080 is overkill
Looking at pricing in spain 1070 is the way to go, Vega is 600 EU, not very worth it, 1070 pricing is still inflated there though.
You should have just kept that 980ti, OC'd it keeps up with pascal very well.
https://es.pcpartpicker.com/product/Tv38TW/evga-geforce-gtx-1070-8gb-sc-gaming-acx-30-video-card-08g-p4-6173-kr
I guess that makes the Aorus the better one? And as a bonus it has the 11gps memory.
Is the Aorus a good cooler?
It seems you're constantly upgrading your gpu just because of some minor performance increase. Be satisfied with your purchase, rather than constantly upgrading.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
I already have a 1080.
I got a refund due to an rma and with the refund I can get either the Aorus or the amp.
That's why I am asking between those two models.
I'd personally go Zotac.
Personal Desktop":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
Luna, the temporary Desktop:
CPU: Intel Core i7 10700KF @ 5.0Ghz (5.1Ghz 4-core) |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Z490 UD |~| RAM: 32G Kingston HyperX @ 2666Mhz CL13 |~| GPU: AMD Radeon RX 6800 (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver)
 Share
