Posted October 15, 2017 I have an asus X550za, it only supports 2.4ghz. I have an ASUS 1750AC router. I have 100/10Mb/s internet When I move outside the room with the router, I get 0.2 mb/s, but when I am in the same room I get 30 mb/s, both rooms have 5 bars signal strength. How could I fix this? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2017 If the signal is still strong then it may be 2.4ghz interference from something nearby. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2017 It's wifi, what did you expect PSU Nerd | PC Parts Flipper | Cable Management Guru Helpful Links: PSU Tier List | Why not group reg? | Avoid the EVGA G3 Helios EVO (Main Desktop) Intel Core™ i9-10900KF | 32GB DDR4-3000 | GIGABYTE Z590 AORUS ELITE | GeForce RTX 3060 Ti | NZXT H510 | EVGA G5 650W Delta (Laptop) | Galaxy S21 Ultra | Pacific Spirit XT (Server) Full Specs Spoiler Helios EVO (Main): Intel Core™ i9-10900KF | 32GB G.Skill Ripjaws V / Team T-Force DDR4-3000 | GIGABYTE Z590 AORUS ELITE | MSI GAMING X GeForce RTX 3060 Ti 8GB GPU | NZXT H510 | EVGA G5 650W | MasterLiquid ML240L | 2x 2TB HDD | 256GB SX6000 Pro SSD | 3x Corsair SP120 RGB | Fractal Design Venturi HF-14 Pacific Spirit XT - Server Intel Core™ i7-8700K (Won at LTX, signed by Dennis) | GIGABYTE Z370 AORUS GAMING 5 | 16GB Team Vulcan DDR4-3000 | Intel UrfpsgonHD 630 | Define C TG | Corsair CX450M Delta - Laptop ASUS TUF Dash F15 - Intel Core™ i7-11370H | 16GB DDR4 | RTX 3060 | 500GB NVMe SSD | 200W Brick | 65W USB-PD Charger Intel is bringing DDR4 to the mainstream with the Intel® Core™ i5 6600K and i7 6700K processors. Learn more by clicking the link in the description below. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2017 1 hour ago, JDE said: It's wifi, what did you expect ^ Connect some of newer devices on 5ghz channel for larger bandwidth but the range is lower than 2.4ghz. Also what speed test are you using? You should use iperf for actual wifi performance results. Magical Pineapples
