PC build for a Friend (~600USD)
I have a pcpartpicker made up already and would like some revisions on it if possible :)
She is looking for a PC for Video Editing and Gaming for nothing over 600 USD, (pretty slim eh?)
And yeah that's about it!
Here's the link ; https://pcpartpicker.com/list/dgQ7tJ
Thanks in advance.
Want any Graphic design or Motion design? Hit me up via the Site, or adding me on skype @ NyxeonFX
looks good. maybe sqeeze in a 120GB ssd
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
Possibly, Thanks for the suggestion :)
Thanks in advance.
At that price, well.. its mostly the best you can get.. but try to get an SSD instead... it is soooo much faster than an hdd.. your entire system will be stuck at the hdd speed
maybe like get a 120 gb ssd and a 1 tb hdd ?
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
Any computer build nowadays MUST use a SSD , it's a huge difference and it is affordable now
Alright i'll squeeze that in there, thanks :D
Added one for $53, just under the $600 mark.
it should only add 60$ max to the build. you could even source one used for half the price
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
Definitely get an SSD.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($109.89 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($69.99 @ Amazon)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($77.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($77.99 @ SuperBiiz)
Storage: Western Digital - RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($35.30 @ Amazon)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($143.98 @ Newegg)
Case: Deepcool - D-Shield ATX Mid Tower Case  ($29.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ Amazon)
Total: $592.12
Spend $20 more for the Prime B350-Plus if you want a better/nicer mobo. I'd try to spend an extra $30 on the case for a Phanteks Eclipse P300. Maybe grab a used GTX 960(same performance as a 1050Ti) for $100 or GTX 970 for $150.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
You won't regret it...
HDD read speed is like 150 Mb\sec
SSD read speed is like 550 mb\sec
its huge.. and the write speed is huge difference too
Total: $592.12
Sweet!~ Thanks for the suggestion! Will keep that in mind :)
I recently heard about Intel's Optane Memory, is that a viable option?
SCRATCH THAT it won't work with Ryzen im slow ^_^
I think it works with intel only,
I dont know much about it, but i wouldnt worry about that at all..
Just get enough memory, and SSD and it will be fast. Of course the ryzen 3 is the weakest of the ryzen, but its hard to do better with ur budget
yeah will do, its kind of hard working with a tight budget :/
its fine.
She will like it. I hope she knows how to reward you after ;)   ( if its ur sister or something i apologise for this joke )
