ryzen Ryzen and 3200 Mhz RAMs question
Solved by johndms,
1 hour ago, Ganuza_ said:So, with my humble GTX 950 is gonna be almost the same with 2400 or 3200? In some videos you can see up to almost a 30 fps range between 2400 and 3200 Mhz (but with a 1080/ti, of course)
I'll just leave you with the two bookmarks I usually refer to when people are concerned about the differences between ram frequency on Ryzen. You can decide for yourself which frequency you'd prefer.
https://www.youtube.com/watch?v=mOWx5LH4uBo
http://forum.asrock.com/forum_posts.asp?TID=4963&title=ryzen-ram-frequency-and-gaming
