90W Power adapter for use with a Dell XPS 15 9560
Solved by IgorM,
10 minutes ago, davidst95 said:Hi, my Dell XPS 9560 came with a 130w power adapter. Is it possible to use a Dell 90w power adapter? I would like to get something a little slimmer and lighter for travel. I have a Dell XPS 13 with a 45W and tested it with my XPS 15. It charged but at a much slower pace. I'm not sure if this is safe or not. They both produce the same amount of amp output. Thanks.
David
are you sure the amps are the same? Because if so the voltage is different and you won't be able to charge. As long as you use the same voltage but the amperage is lower it will charge but slower. By the formula Power = Voltage x Current, for example if you have a 40w charger at 20v the current will be 2 Amps
