So I've recently gotten a 1080ti (and an Oculus rift + 4 port USB card) the rest of my setup has stayed 100% the same.
I've got some noise issues since then, but only while gaming. However, I just found out, it's not the fans on the GPU. How do I know? Well, even when the fans are perfectly still (even while gaming) the noise is still there. I checked all other things, stopped some fans like the south bridge fan, but still have no clue. I even filmed it. It's clearly not the GPU fans, but it sure does sound like it's coming from the GPU.
Anyway, can a GPU make this noise, without fans spinning?
And if you guys are sure it's the GPU, I should probably return it, right?
I'm dutch, so feel free to correct any spelling mistakes I might make.  I try to do the best I can!
CASE: Fractal Design Define R6 MOBO: Asus ROG Maximus XI Hero (Wi-Fi) CPU: Intel Core i7-9700K GPU: Asus ROG-STRIX-GTX1080TI PSU: Corsair HX1000 V2 MEM: 64GB G.Skill Trident Z RGB 3200mhz  COOLER: be quiet! Dark Rock Pro 4 STORAGE: Samsung 970 EVO 500gb +1tb NVME / Samsung 840EVo 1tb / HGST Ultrastar 10tb
If it's that high pitched noise I hear, that's coil while.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
It shouldn't be this bad, right?
1 hour ago, Delano.888 said:
-snip-
Yep, thats coil whine
Now lets get to to the real important topic here.....
YOU HAVE THE SAME CASE AS ME :D
How could I tell? Because I know this case all too well! :)
It's simply the best case ever. Probably never changing. I should clean it though.
I wonder how you saw, I barely filmed the case.
I just know my case too well, between the 200mm top fans, the angled E-atx cutouts and the bottom panel with nearly open mesh for the super long PSU filter... I'm a huge nerd for cases and when I was building in 2014 I spent months doing research on all the cases before i settled on this one.
It can be. It goes away though. Just use your GPU and it'll fade overtime.
