''New Malware Can Jump Air Gaps Using Inaudible Sound''
TopWargamer
http://gizmodo.com/new-malware-can-jump-air-gaps-using-inaudible-sound-1475444169
A team of computer scientists has developed a new breed of malware, which can leap between devices using inaudible audio signals—then covertly transmit passwords and other sensitive data without a network connection.
Using just built-in microphones and speakers, the researchers can transmit passwords and other small quantities data over distances of 65 feet.
So basically if you get this malware, there's 2 known facts:
1) You're screwed.
2) The person doing the screwing is close by.
AT LEAST it's only the researchers who have access to this as of right now. That could very well change soon. When there's a will, there's a way.
COMIC SANS
Dahm that is really impressive!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
Im scared :c
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
THIS IS GENIUS!
AMD FX 8320@ Stock - Asus M5A99X Evo R2.0 - Kingston HyperX 8GB 1600Mhz - Corsair Carbide 200R - Powercolor Radeon HD 7950 PCS+OC@970Mhz core 1400Mhz memory - Corsair CS650W - Samsung 840 EVO 250GB
LG 22EA53VQ 21.5" - CM Storm Xornet - CM Storm Quickfire TK - Creative Inspire T3130 2.1
No need to be worried.. Nothing will happen.. This would require you to have already downloaded malware that would listen in on the microphone.. Both articles have taken it out of context..
CPU: i7 4770k | GPU: Sapphire 290 Tri-X OC | RAM: Corsair Vengeance LP 2x8GB | MTB: GA-Z87X-UD5HCOOLER: Noctua NH-D14 | PSU: Corsair 760i | CASE: Corsair 550D | DISPLAY:  BenQ XL2420TE
Firestrike scores - Graphics: 10781 Physics: 9448 Combined: 4289
"Nvidia, Fuck you" - Linus Torvald
old news... can't be arsed to quote right now but there were 2 or 3 articles in like the last month or two about the BadBIOS malware that allegedly jumped air gaps using sound...
Yeah it's completely bs and wouldn't work in the first place. Microphones are the only way this can be done but they aren't sensitive enough to replicate the data well enough that there won't be errors.
Total and utter bollocks people, stop believeing everything you read on the internet. How is a device supposed to register the signal from audio waves without local software interpreting the sound via a microphone in the first place? And if they managed to put THAT on your device, well they might as well have dropped the malware off instead.
What this is saying is that it's possible to transmit data via sound, something that I think old morse code operators could have told you.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
