Good black and white build with possible cablemod parts.
DaRedBoi
Go to solution Solved by Shiv78,
Bit over, but switched you to a better CPU, faster RAM with white LEDs, good mobo, and a (white) GTX 1070! also you could consider a P400S TG white edition or black/white edition as well.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.08 @ OutletPC)
CPU Cooler: Deepcool - CAPTAIN 240EX WHITE 153.0 CFM Liquid CPU Cooler  ($99.99 @ B&H)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($131.98 @ Newegg)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3200 Memory  ($148.99 @ Newegg)
Storage: Samsung - 850 Pro Series 256GB 2.5" Solid State Drive  ($114.99 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.78 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($443.88 @ OutletPC)
Case: Phanteks - Enthoo EVOLV ATX ATX Mid Tower Case  ($139.99 @ Amazon)
Power Supply: Corsair - RMx White 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($149.99 @ Amazon)
Total: $1471.67
Generated by PCPartPicker 2017-09-09 10:21 EDT-0400
Hi, everyone, I was wondering if you guys knew anything for a black and white pc build.
I have already made one on PC part picker but I wanted you guys to see if I should change anything. My requirements are a z270chip and 16 GB ram. I also want a white PSU. If you guys can't do a white psu then you can save some money from other pc parts and get cablemod parts.
Link?
PSUs either come in metal grey (and most of those are cheap ones) or black, so white ones are impossible to find.
Desktop benching:
i5's arent worth buying since the release of Ryzen, a 1600 would be a better choice.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
1. Coffee Lake is not far away, so buying Intel chips now is a bad idea
Desktop benching:
Why Z270? The 7600K is pretty much equivalent to the 1600, but worse at multitasking, and multi threaded workloads.
As for the rest of the build. G. Skill Trident Z in black and white goes nice in a black and white build. No need for an 850 Pro, an Evo would be fine. The MSI Armor is their lowest end cooler, so get a better one. Maybe change the case to the P400 TG in black and white, to better match the theme? The RM750x is plenty, and is white. If you decide to get the P400, the PSU won't show, so you can get a cheaper one.
Edited by seon123
Damn autocorrect
Just now, DaRedBoi said:
is 1600x ok
1600 or 1600x are the same chip themselves, but 1600x doesnt come with a cooler. It doesnt have RGB and it's black so you might not want to use it. In this case, get the cheaper one
Desktop benching:
i dont need a stock cooler im getting a liquid one
is the luxe ok
I also really like the glossy white/black h440
Total: $1471.67
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
I also want a white psu it comes with white cables instead of shelling out an extra 100 on cablemod
Total: $1471.67
thanks
CPU Cooler: Enermax - ETS-T50 AXE (White) 62.3 CFM CPU Cooler  ($54.99 @ Newegg)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($111.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($138.89 @ OutletPC)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Video Card: EVGA - GeForce GTX 1080 8GB FTW DT GAMING Video Card  ($539.89 @ OutletPC)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($85.98 @ Newegg)
Power Supply: Corsair - TXM Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($89.99 @ Amazon)
Other: CableMod® ModFlex™ Basic Cable Extension Kit - 8+6 Pin Series - WHITE ($34.90)
Total: $1388.47
Generated by PCPartPicker 2017-09-09 10:34 EDT-0400
Why do you need a White psu ? That case has a psu shroud. If you are not going to SLI then a 550W psu is enough.
the evolv atx has a little hole to see the logo and the white psu is a better deal for me because I spend 30 dollars more instead of 90 dollars more for cablemod cables.
It also looks nice while im working with it
But if you look at the side panel (Bottom left part) it is raised a bit where the cut out is so the psu shouldn't be visible. Also a Black psu still fits in with a black/white design.
Also the Black version of the Corsair RMx 750W is $30 cheaper (Assuming you are in the USA). You can still use the Black/White Cablemod cables just the same.
The white RM750x comes with white individually sleeved cables.
I wasn't aware of that. Thought it was just the different coloured housing. Pretty good value then.
Stick with it then. As mentioned by Seon it already has the White cables which I was unaware of.
ok
[PCPartPicker part list](https://pcpartpicker.com/list/BBfp6X) / [Price breakdown by merchant](https://pcpartpicker.com/list/BBfp6X/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor](https://pcpartpicker.com/product/8hwqqs/amd-ryzen-5-1600x-36ghz-6-core-processor-yd160xbcaewof) | $226.09 @ OutletPC
**CPU Cooler** | [Deepcool - CAPTAIN 240EX WHITE 153.0 CFM Liquid CPU Cooler](https://pcpartpicker.com/product/Dz648d/deepcool-captain-240ex-white-1530-cfm-liquid-cpu-cooler-captain-240ex-white) | $99.99 @ B&H
**Motherboard** | [ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard](https://pcpartpicker.com/product/LgmxFT/asrock-x370-killer-sliac-atx-am4-motherboard-x370-killer-sliac) | $131.98 @ Newegg
**Memory** | [Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-2666 Memory](https://pcpartpicker.com/product/NctWGX/corsair-vengeance-rgb-16gb-2-x-8gb-ddr4-2666-memory-cmr16gx4m2a2666c16) | $139.99 @ Amazon
**Storage** | [Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive](https://pcpartpicker.com/product/3kL7YJ/samsung-internal-hard-drive-mz75e250bam) | $89.99 @ B&H
**Storage** | [Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/44Gj4D/seagate-barracuda-1tb-35-7200rpm-internal-hard-drive-st1000dm010) | $44.78 @ OutletPC
**Video Card** | [GALAX - GeForce GTX 1060 6GB 6GB EX OC White Video Card](https://pcpartpicker.com/product/GJyxFT/galax-geforce-gtx-1060-6gb-ex-oc-white-video-card-60nrh7dvm3we) | $320.00
**Case** | [Phanteks - Enthoo EVOLV ATX ATX Mid Tower Case](https://pcpartpicker.com/product/bNQRsY/phanteks-case-phes515ebk) | $139.99 @ Amazon
**Power Supply** | [Corsair - RMx White 750W 80+ Gold Certified Fully-Modular ATX Power Supply](https://pcpartpicker.com/product/WHPzK8/corsair-rmx-white-750w-80-gold-certified-fully-modular-atx-power-supply-cp-9020155-na) | $149.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$1342.80**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-09-09 10:59 EDT-0400 |
3 hours ago, DaRedBoi said:
lol that is what pcpartpicker told me to copy/paste
Here, I'll fix it for you. You copied the Reddit formatting, use the [bb] button. Lol
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor  ($226.09 @ OutletPC)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-2666 Memory  ($139.99 @ Amazon)
Video Card: GALAX - GeForce GTX 1060 6GB 6GB EX OC White Video Card  ($320.00)
Total: $1342.80
Generated by PCPartPicker 2017-09-09 14:59 EDT-0400
HOLA NIGHT THEMERS
OTHER TECH I OWN:
