URGENT!! PC IS BEEPING
Timbs
Hello, I just got done with a memory upgrade. I was previously at 14GB, and went to 18GB. However, my motherboard only supports up to 16GB. I can't take out the 2GB stick, as then it would be tri-channel. That is the only thing I messed with, could that be the issue?
CPU: Intel Core i5 2400 GPU: MSi GTX 1050 Ti 4GT OC RAM: 14GB DDR3 (3x2GB, 1x8GB) Mobo: Acer MB.GAU07.001 Case: Gateway DX4860 PSU: EVGA 600W Bronze Plus
If the ram isn't matched, then take out the unmatched ram and try booting.
It's generally not recommended to have all sorts of ram from different brands
It's not reccomended, but it will work 99% of the time.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
It could be the issue....
Today I learned that Acer made motherboards...
/s
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
  Reveal hidden contents
/s
Believe it or not, so does every pc oem manufacturer
*UPDATE*
After a bit of searching around, the beep codr I get (Long, continuous), is RAM or GPU related. If ypu don't get signal, its GPU. I am noy getting any signal. I have reseated the GPU several times and nothing is helping. Any help is appreciated.
*ANOTHER UPDATE*
Fixed the issue. The memory I received was the culprit the whole time. After booting with another GPU I had laying around, and then no GPU, I narrowed it down to the memory. I removed  1 4GB stick, and placed in one of my old 2GB sticks, giving me exactly 16GB. Still had the booting issue. Then I just replaced the other 4GB stick with my other 2GB stick, and it booted right up! Glad to say that my GPU isn't fried.
