Search In
  • More options...
Find results that contain...
Find results in...
Need help with my Vape
FlushaDev
 Share
I just bought the new TFV12 yesterday and paired it with my Alien 220w Mod, the mod has it's Ohms preset at 0.11 for the coil, and the coil that I installed says 0.12Ohms on it, would anything happen if I manually changed the Ohms to 0.12, and if I did that, would anything change? (Battery Usage, Cloud Size, E-Juice).
"The only way to do great work, is do do what you love." -Steve Jobs
There's no point as the mod automatically reads the resistance of the coils. Sometimes coils will read in slightly differently than what they say. And no, nothing would change.
Thanks for the response, even tho kinda late, still useful
 Share
