Which Power Supply is better for my 1080Ti
A5Gold
So Should I use Antec EDGE750W or CoolerMaster V750 for my system?
CPU
Intel Core i7-7700K
GPU
Msi GTX 1080Ti GAMING X 11G
MB
GIGABYTE Z270X-UD5
RAM
Corsair Vengeance RED 8GBx2
HDD
WD Blue 1TB 7200rpm
SSD
SAMSUNG 960 Evo 500GB M.2
CPU
Intel Core i7-7700K
GPU
MB
GIGABYTE Z270X-UD5
RAM
HDD
WD Blue 1TB 7200rpm
SSD
Both are good but I'd get the Cooler master V.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
A quick look  at the psu tier list shows that the cooler master would be the better choice, but the Antec has much better reviews. You should consider Seasonic power supplies, they beat anything in the same price range.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
Cooler Master V.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
The Cooler Master is a Seasonic power supply.
That's not really true. Saying that Seasonic has the best price/performance isn't really true and is just ignoring great product offerings from other manufacturers and brands.
