Samsung 850 Pro 256GB partition question
Solved by PhiberOptik,
TIL
Question 1: Fixed it by deleting the recovery partition(you will have to disable system protection), installing Samsung 4.X and then choosing clear OP, that got me all my space back, then I installed 5.X and reprovisioned it. This only works if the partitions are next to each other.
Question 2: Just a place holder screen actually doesn't show anything relevant
Question 3: Reprovisioned with 5.X seems any unallocated space is called over provisioning and doesn't require any special treatment to function as such.
Question 4: Yes =D, but seems 5.X could have done it too.
