Corsair H100.
Switched cases today. When I turned on my pc, it just said poof and and the lights on the cooler vanished.
There was a strong smell of something fried.
So I think I short circuited something, and my guess is the cooler is a rip, it's not lightning up anymore and my fans (which are connected to the cooler) isn't spinning.
What else should I check?
It boots but it just says CPU fail or something, press F1 to setup. But nothing happens when I press F1... Could the USB ports be cucked?
The motherboard lights up, the GPU lights up and spins up.
If the CPU is alright I was thinking about picking up a NZXT KRAKEN X62.
Specs
i9 9900K 5.1GHz 0 AVX offset
ASUS MAXIMUS APEX XI
Custom watercooling (360mm, 60mm thicc)
EVGA GTX1080 FTW DT
EVGA T2 1000W Platinum PSU
3200MHz G.Skill RGB B-die
Samsung 970 Pro 512GB
Samsung 860 EVO 2TB
Crucial MX300 1TB
https://linustechtips.com/topic/814212-cpu-cooler-said-poof-what-to-check/
Did you remember to install your motherboard standoffs?
CPU cooler is dead, it wont let you boot into windows, you need to get a new one m8, only way.
Editto: The fan on the cooler is dead, you just need to get a new fan.
If you need help on used parts, contact me. I'm an used enthusiast.
Open the spoiler to see some cool stuff!
My old/new tech Collection!
CPUs (11)
Intel Pentium III @ 733Mhz (Oldest of the Bunch)
Intel Pentium 4 @ 2.8Ghz (2002)
Intel Pentium 4 @ 3.0Ghz (2003)
AMD Sempron 64 2800+ @ 1.6Ghz (2004, Aug)
AMD Athlon 64 3500+ @ 2.2Ghz (2004, Jun)
2X Intel Xeon X5355 @ 2.66Ghz (2006, Q4)
Intel Pentium E2140 @ 1.6Ghz (2007, Q2)
Intel Xeon E5630 @ 2.53Ghz (2010, Q1)
Intel Core2 Duo E8400 @ 3Ghz (2008, Q1) (In use, @ 3.61Ghz)
Intel Pentium E6500 @ 2.93Ghz (2008, Q1)
GPUs (6)
Palit GeForce 6800 GS (Should be working, AGP 8X)
Club 3D GTS 450 (Working, PCI-e 16x)
Sapphire Radeon X800GTO (Working, PCI-e 16x)
Nvidia GeForce 4 (Last time worked, AGP 4X)
Nvidia GeForce FX (No idea, AGP 4X)
Gigabyte Radeon HD 7970 OC (Semi-dead, PCI-e 16x)
Ram (1)
No idea of the brand or Socket (Whopping 16 Mb memory)
Cables (1)
CrossFire X Cable
I thought the Corsair 750D had built in standoffs? Looked like it.. :/
Fans are working, cooler unit is not. Rip
Specs
EVGA GTX1080 FTW DT
Samsung 860 EVO 2TB
Crucial MX300 1TB
well, you dun fucked up... maybe the cooler got a shortage due a leakage if the liquid in there is conductive.
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
I'll just take it down to a local pc shop, I can't really see why it short-circuited. No leaks as far as I can see..
Specs
EVGA GTX1080 FTW DT
Samsung 860 EVO 2TB
Crucial MX300 1TB
Make sure that you took the plastic film off the bottom of the cooler and that there is thermal paste there. Also make sure that its tightened down and its all connected properly. If those are all true then return it.
Have you tried turning it off and on again?
It was fried and dead, bought a new one. X62
Specs
EVGA GTX1080 FTW DT
Samsung 860 EVO 2TB
Crucial MX300 1TB
