1. Budget & Location
~3000$ CAD
2. Aim
Gaming and trying to start streaming
3. Monitors
1 to start but 2 is the end goal
4. Peripherals
Just need Windows
5. Why are you upgrading?
Razer(2013) Laptop outdated and cant keep up
Here's 2 builds I've been considering
https://ca.pcpartpicker.com/list/34WFNN
https://ca.pcpartpicker.com/list/zZNdVY
Not sure if i should go with the Intel or AMD more familiar with Intel but everyone seems to prefer AMD for the cost effectiveness and in multi tasking.
Also contemplating a 1080 instead of the Ti just unsure if it will be enough for the 144/165hz monitors
Monitor is also up for discussion I loved the looks of the Asus ROG Swift PG278QR/PG279Q  but the price is quite high. Also somewhat confused on the TN/ISP will I notice the 1ms or 4ms difference and is it worth the extra $
ROG Strix GPU was chosen mostly for the quietness, temp and aesthetics
Color Scheme goal is Black/Purple/Green
Any general feedback is appreciated still fairly new when it comes to PC parts so i might be investing to much where is not needed or not enough.
https://linustechtips.com/topic/814128-first-pc-build-looking-for-guidance/
For night theme users:
. Budget & Location
~3000$ CAD
2. Aim
3. Monitors
4. Peripherals
Just need Windows
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Are you planning on using NVENC or x264? If x264, go ryzen. Get a modular power supply though.
Current LTT F@H Rank: 69    Score: 3,457,572,143    Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 3900X w/PBO on
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 6.12.4
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
PSU: EVGA G3 850W
SSD: Samsung 980 Pro 1TB NVME, Samsung 970 evo plus 1TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (3x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Go for the AMD one
TN panels have a fast response time, which doesn't really matter IMO, and they also have horrible angles and eh colors, IPS on the other hand have great colors and viewing angles so I would strongly recommend going for IPS > TN
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Tbh I haven't really looked into anything on what I'm going to do for streaming, computer now isn't capable so I've been waiting till I upgrade to start that journey. Any modular PSU you would recommend?
2 minutes ago, Brooksie359 said:
well what games are you planning on playing? because my 1070 can get those fps numbers for those monitors in games like overwatch.
Overwatch, PUBG, WOW, Anthem, Destiny 2, Hearthstone pretty much any solid fps and some mmorpgs mixed in, making the switch from console because mouse>controller and PC master race
Darn, modular-ness really increases price at this wattage... This is quite a bit more expensive, but I recommend it: https://ca.pcpartpicker.com/product/y88H99/evga-supernova-g3-650w-80-gold-certified-fully-modular-atx-power-supply-220-g3-0650
Unless you don't care about modular-ness, in which case the the PSU you have now should be good.
My main PC:
OS: Windows 11
OS: unRAID 6.12.4
PSU: EVGA G3 850W
3 minutes ago, QuantumBit said:
Go for the AMD one
I was kinda leaning towards ISP well my thoughts were I'd take the hit on quality to save money but in the long run I don't think it'd be worth especially if I'm watching anything on the PC
I think I originally had that PSU and swapped it for the cheaper one not fully understanding the difference and I think you're right I should go modular
9 minutes ago, TheGlenlivet said:
R7 for streaming and gaming.  1080ti for 2 monitor 144hz at 1440p.  I think most on this forum will agree.
What do you think of the MOBO on the R7 build, was a toss up between that and the Gigabyte Gaming K7
17 minutes ago, Sweet Nectar said:
Do you think ill have problems with the RGB going with the Gigabyte?
Oh yeah, RGB...
Well if you want to make it all work together with one software control then you should get the strix.  The gigabyte is a higher tier board though.
6 minutes ago, TheGlenlivet said:
Oh yeah, RGB...
but really It'd just be a difference of 1 program as apposed to 2 programs if I went with the Strix so not like the end of the world I guess, or is it more complicated than that?
Just now, TheGlenlivet said:
No, but the software for this kind of stuff is usually pretty junky.  If it's important to you how the RGB looks, as important as the performance of the system, then do the strix.
i wont be doing any like crazy light shows or anything mostly trying to find easy ways to incorporate the purple and green in so they'd be fairly simple colors to match I would imagine
So you're going with IPS?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
I'm thinking so yeah, i think I'd have to go to the store in person to actually see the difference for sure but yeah I'm thinking. IPS raises my costs quite a lot especially if I'm doing two monitors though which is unfortunate but hopefully worth it in the long run
6 minutes ago, MCNX said:
PCPartPicker part list: https://ca.pcpartpicker.com/list/YJWNhq
Price breakdown by merchant: https://ca.pcpartpicker.com/list/YJWNhq/by_merchant/
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($434.50 @ Vuugo)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($124.99 @ Memory Express)
Motherboard: Asus - STRIX Z270F ATX LGA1151 Motherboard  ($242.99 @ PC Canada)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Amazon Canada)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($209.99 @ Newegg Canada)
Storage: Western Digital - BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($150.75 @ shopRBC)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card  ($1036.99 @ Newegg Canada)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($109.99 @ DirectCanada)
Power Supply: Rosewill - 700W 80+ Gold Certified ATX Power Supply  ($79.99 @ Newegg Canada)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($179.50 @ Vuugo)
Total: $2734.68
Generated by PCPartPicker 2017-07-28 21:10 EDT-0400
Think you could give me some of your thought process on this?
14 minutes ago, MCNX said:
pretty much this computer will be about the same has you wanted it before except i changed a few things like hard drives and ram. the hard drives will be better and faster and the ssd will have more space. The ram will be cheaper with it not having the RGB. but if you want the RGB still you could add it but it will add to the price and I lowered the price of the motherboard
though I still think this is a bit overkill and that some stuff could be changed
 I do agree you should. If you have the patience everything will be cheaper and it would be worth it.
so many choices makes this super difficult. Even just the Intel vs AMD fight is hard enough haha. From the start I was caught on Intel I just find there so many more choices especially MOBO wise and they match nicely with the GPU but the price difference is very substantial. Intel has new cards coming out right? Think that'll lower the cost of the 7700k?
