Hello there!
So I want to make both a LAN and video capture PC so I can get back into video making again as well as have friends over. Before I make it however I would like to know how much it is actually worth since I don't want to waste money/go over the 'too expensive' threshold when building it.
Here are the specs:
- Q8200 @2.33GHz
- Dell XPS 630i TED-C113J Motherboard
- 6 or 8GB of DDR2 RAM
- GTS 250 512mb in SLI
- 160GB HDD (With Windows 10 64-bit)
- CiT Ignition ATX tower
- 650W PSU
- DVD R/RW
- 761H PCI-E HDMI Video Capture Card
- Linksys 2.4GHz PCI Wireless Card
I already own one GTS 250 so I just need to buy the other.
I was thinking that it is maybe worth £150 - £200 with but I could be wrong... Please let me know the value!
Thanks - BP
IT Manager working in the Education sector.
https://linustechtips.com/topic/814125-how-much-is-this-system-worth-%C2%A3/
$100-$150.  Integrated graphics is now as powerful as that GTS 250.   CPU is worth $10.  Power supply and case may be the most valuable parts along with the RAM.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
I'm confused, are you building a PC or selling one?
Current LTT F@H Rank: 69    Score: 3,457,572,143    Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 3900X w/PBO on
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 6.12.4
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
PSU: EVGA G3 850W
SSD: Samsung 980 Pro 1TB NVME, Samsung 970 evo plus 1TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (3x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Building one, however I want to build one where I am not overpaying for the whole system. (If it was being sold as a whole system for a certain amount by someone else, I wouldn't want to go over that amount when building so that I am getting the best 'bang for buck')
Maybe £150 give or take.
The biggest thing of value in there is the capture card and the copy of Windows 10.
The GPU is worth maybe $30 give or take
The processor is around $10 to $15
The RAM could hold some value if it's DDR3
Everything else I wouldn't really put much value into.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
What PSU is that?
My main PC:
OS: Windows 11
OS: unRAID 6.12.4
PSU: EVGA G3 850W
If you're looking to build a solid capture and gaming system, this is about what you'll pay for new:
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  (£98.99 @ Overclockers.co.uk)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (£74.19 @ CCL Computers)
Memory: Kingston - FURY 8GB (1 x 8GB) DDR4-2400 Memory  (£64.26 @ CCL Computers)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive  (£39.47 @ Amazon UK)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.95 @ Aria PC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  (£131.50 @ Novatech)
Case: BitFenix - Neos Black/Silver ATX Mid Tower Case  (£26.40 @ Aria PC)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.90 @ Ebuyer)
Other: Hauppauge Colossus 2 Internal High Definition Video Recorder for PC/Console Gaming  (£109.99 @ Amazon UK)
Total: £633.65
Generated by PCPartPicker 2017-07-28 22:11 BST+0100
For a used system, I would target the $300 to $500 range. Look for a good quad core 2000 or 3000 series processor at least, 8GB of DDR3 RAM, something around the GTX 750Ti range, or maybe even no video card and toss in a 1050Ti yourself, and then toss in a capture card yourself as well.
Prior Build Log/PC:
6 minutes ago, sazrocks said:
What PSU is that?
This is the best I can find for my needs: http://www.ebay.co.uk/itm/Hipoint-650W-PSU-power-supply-48A-on-12V-1x-6pin-pci-4x-SATA-3x-Molex-8pin-/322619629273?hash=item4b1da0ded9:g:lpoAAOSwhuxZejeQ
I know it is an awful PSU however the system will use about 550W at best so there shouldn't be any issues whatsoever on power consumption plus the 12V rails are at 48A so it can't be too bad.
Don't buy PSUs used. Ever. Get a cx 450m or something.
My main PC:
OS: Windows 11
OS: unRAID 6.12.4
PSU: EVGA G3 850W
Case: NZXT - S340 (Black) ATX Mid Tower Case  (£62.39 @ Aria PC)
Power Supply: Corsair - CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£53.39 @ Amazon UK)
Total: £674.13
Generated by PCPartPicker 2017-07-28 22:07 BST+0100
Problem is that I don't have that kind of money. I already have a decent gaming PC (On my profile) within that kind of spec but I just need something to capture RAW footage from my gaming PC/other cheap PC's so that I can get back into making Youtube videos about cheap tech. I will occasionally have a friend round to play games and I need a better 'spare' PC since they can't keep bringing their own cheapo system with them since they can't yet drive.
I am also fond on aesthetics so an SLI PC would make a nice addition to my current PC family.
Had no problem in the past. I've had free PSU's given to me in the past that work perfectly fine.
