Posted July 23, 2017 Who has the best color for liquid cooling? I want white dye ek doesn't have white so I'm wondering who else has ones that are proven good Link to comment https://linustechtips.com/topic/811547-best-color-coolant/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 23, 2017 Check out Mayhems, https://mayhems.co.uk/ They make some great coolant. Current Network Layout: Current Build Log/PC: Storage Server Setup: Prior Build Log/PC: Link to comment https://linustechtips.com/topic/811547-best-color-coolant/#findComment-10185828 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 23, 2017 Author 11 minutes ago, Lurick said: Check out Mayhems, https://mayhems.co.uk/ They make some great coolant. What's the difference between pastel white and mayhem pastel extreme Link to comment https://linustechtips.com/topic/811547-best-color-coolant/#findComment-10185869 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 23, 2017 Just now, nfs2192 said: What's the difference between pastel white and mayhem pastel extreme The extreme can be mixed with less water for a more intense color. Current Network Layout: Current Build Log/PC: Storage Server Setup: Prior Build Log/PC: Link to comment https://linustechtips.com/topic/811547-best-color-coolant/#findComment-10185874 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 23, 2017 Extreme is ethylene glycol (and maybe propylene glycol, Mayhems is gray about this one) so is not compatible with PETG. Pastel is supposedly glycerol based so should be okay with PETG. Both are pretty poorly documented, but probably your best bet if you want an opaque fluid. 16 minutes ago, nfs2192 said: What's the difference between pastel white and mayhem pastel extreme Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment https://linustechtips.com/topic/811547-best-color-coolant/#findComment-10185911 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 24, 2017 16 hours ago, For Science! said: Extreme is ethylene glycol (and maybe propylene glycol, Mayhems is gray about this one) so is not compatible with PETG. Pastel is supposedly glycerol based so should be okay with PETG. Both are pretty poorly documented, but probably your best bet if you want an opaque fluid. Apparently the blues and greens are less likely to fade and "fall out" compared to the yellows, oranges and reds. Something to bare in mind for a colour themed setup. I've had the red in several systems and haven't had an issue yet, but just thought I'd flag it up for the sake of awareness. Link to comment https://linustechtips.com/topic/811547-best-color-coolant/#findComment-10189073 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
