J-Channel Cable Raceway UK
I'm on the hunt for some new cable management gear to make my setup actually look more presentable. I'm planning on buying a J-Channel raceway, some 3M tape, and some heavy duty cable clips, among other misc items like cable ties.
My main problem is that I can't for the life of me find a J-Channel raceway in the UK. I saw one in this video:
And I decided that having a cable raceway would be a good idea. I found a few, but they were more like cable trunkings designed for projectors and wall-mounted TV's, not with the J-Channel that I'd need in order to feed off different cables at different times. Everything else I can find quite easily, it's just the raceway that's proving a few problems. I would hold off of buying a signum from IKEA because I don't really like how the cables are still visible, but right now it seems the only way I can get a raceway is by importing one, which I'd also rather not do.
If anyone can find a relatively cheap raceway in the UK then I would be extremely grateful. My entire budget for cable managing is £50 but I'm aiming to not use all of it
(Also, I'm not sure if this is the right category to post this, I couldn't find anything that would suit the topic).
https://linustechtips.com/topic/811428-j-channel-cable-raceway-uk/
  • 2 months later...
  • 2 months later...
