No video signal and screen resoltion problem
Go to solution Solved by Pyrofunto,
38 minutes ago, Pyrofunto said:
Ok i've got another problem now...
Now everything is working fine except the screen resoltion. It tells me it is 1080p but I can see it is ugly af and it is definately not 1080p. Any help? Also, I had to resize it...
Ok got it fixed idk how... When I changed the hdmi input of the cable (it was on hdmi 2 and i put it on 1) and it is now back to normal
Hey guys, I am here with my PC and when I try to turn it on my screen says no signal, it was working fine just before the vacations. As both GPU and CPU are overclocked I tried to take out the GPU and connect the cable to the motherboard but still nothing, I connected a fan to check if the MB was working and it is.
If it helps here are the specs:
PS= EVGA 430W
MB= MSI H81M-E33
CPU= i7 4790
GPU= GTX 960
https://linustechtips.com/topic/811046-no-video-signal-and-screen-resoltion-problem/
Try to change your monitors input using the menu options. May of accidentally changed it to analog
If this post solved your problem, please press the check below :).
Just now, Pyrofunto said:
I tried already, even tried with a HDMI and a VGA cable none works
Do you have any other HDMI or VGA cables laying around you can try to see if your cord broke?
Just tried them with another PC and they work just fine
Ok, did you try using another port?
Ok, this seems like a graphics card or monitor problem. Could you try and use another monitor? If that doesn't work you may need to ask someone else as graphic cards are not my forte, but it seems to me that maybe your graphics card broke.
Monitor isn't the problem, it works with another PC. GPU isn't the problem either because if it was it should work when i try to run without it
Hmm, I don't know then. Sorry that I was unable to assist you in your problem. :(
Reset CMOS, then try again.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Google it... sorry not being funny with you, but the amount of times people have to spoon feed people the answer makes people mad.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Yeah sorry didn't tought about that, I just did it and still no signal...
OK, list your specs or link to a pcpartpicker list. How long have you had the PC? did you build it? experience with building PCs?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Specs:
PS= EVGA 430W
MB= MSI H81M-E33
CPU= i7 4790
GPU= GTX 960
Had it for 3 or 4 years but i upgraded it over the time. Built it myself, not a pro but I know what I am doing when building a PC.
Specs:
PS= EVGA 430W
MB= MSI H81M-E33
CPU= i7 4790
GPU= GTX 960
OK, can you do me a favour and set your text colour to auto please, I'm using night theme and have to highlight the text to see what you wrote if not.
Well as you've had it that long and got things working before when upgrading at least that rules out common new builder problems like connections not in properly. What's the last hardware related thing you changed? and how long ago?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Last thing was the GPU a year ago
OK, we'll start off doing a minimal hardware test... take out everything except 1 stick of ram and boot SSD/HDD.
So just iGPU/CPU+cooler/1 stick RAM/PSU/HDD and connections left. Power on and see if it POSTs and=or boots into OS.
If no luck, Try reset CMOS again... if you don't have a rest CMOS button, do it by taking out the battery (remember to turn off PSU and press power button a few times to discharge capacitors first), leave battery out for 10 seconds, put it back in and turn on PSU again... then try to start PC again.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Yaaaaay, apparently one of my two ram sticks was the problem because without it it works! Thanks a lot guys!
No problem... glad you got it going again.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
