Search In
  • More options...
Find results that contain...
Find results in...
Need MOBO better than X99 plzz
Hi guys,
I have heard that the Asus X99 are not as great as I first tought they were (may become faulty quick etc.)
I want a mobo that will handle 10+ HDDs in all (some are 8+2 I think we can get 10 with that)
I want to have something that will be the best price value and quality value for the price ** and for the years to come
I think of LGA 2011
what would you guys get if it was you?
and what CPU would you suggest with it !  plzz
t h r e a d r i p p e r
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
At this point I wouldn't go with X99, go with X299 from intel and a CPU that suits your needs so that is 7800X to 7900X (I refuse to recommend 7740/7640X) or wait a little longer for threadripper from AMD.
X99 is just about replaced and you would be buying out dated tech
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Then you should be looking at Ryzen 7's or waiting for threadripper to release.
PC - CPU Ryzen 5 1600 - GPU XFX GTR RX480 8GB- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Proteus Spectrum - Keyboard Logitech G910 Orion Spectrum  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 Driving Force - Shifter - n Logitech Driving Force
Value now and in the future?
X99, as in a year or two used Xeons with 12-16 cores will flood the market alongside cheap DDR4 ECC. Mobos will rise in price then also.
Or Ryzen, if you want just a fast cheap machine now
If I helped, hit the thumbs up icon below my post and pick it as 'Best Answer'
Resident living meme - I swear a lot; if you don't like it fuck off :^)
  My specs and shit down below.
Apollo: i5 4670K @ 4.6Ghz, Corsair H100i, MSI Z87I, EVGA GTX 1070 SC ACX3, Corsair 250D, 840 EVO 120GB, 1TB Seagate Barracuda, SeaSonic 520W PSU. Planned upgrades: 16GB RAM, 480/512GB SSD, new HDD
Sputnik: HP EliteBook 2570p, i5-3360M, 16GB DDR3, 256GB 840 EVO - Running Win10/Sierra dual-boot.  Future upgrades: i7-quad
Comet (home server): Atom D2500, 4GB 1066Mhz RAM, 2 x 320GB HDDs, 350W PSU, HAF-Stacker ITX, dual GbE. Cost me $80. back from the dead (mobo failure) bois
Main peripherals
- Corsair Strafe RGB MX Reds
- SteelSeries Siberia 650
- SteelSeries QcK+ CS:GO Camo
- SteelSeries QcK+ Na'Vi Splash (Secondary pad, used for second rig)
- SteelSeries Rival 700
- SteelSeries Rival 300 (Secondary mouse, used for second rig)
I am really considering the Asrock AM4 X370 Taichi. Mainly for the same reasons. 10x Sata, it has 2x m.2 (not sure if all sata will keep working when in use) and has an overkill on performance. The Taichi also seems to be one of the better boards for getting your high memory speeds, which Ryzen seems to like. (buildzoid, who sometimes does reviews for Gamers Nexus, also has one/plays with one) Overkill on build quality/parts.
Make a Ryzen 7 build with the Asus Prime x370 Pro, although it only has 8 SATA doors :/
x99 is by all means not a good value so it's really hard to recommend it, should really look into Ryzen.
Workstation Rig:
CPU:  Intel Core i9 9900K @5.0ghz  |~| Cooling: beQuiet! Dark Rock 4 |~|  MOBO: Asus Z390M ROG Maximus XI GENE |~| RAM: 32gb 3333mhz CL15 G.Skill Trident Z RGB |~| GPU: nVidia TITAN V  |~| PSU: beQuiet! Dark Power Pro 11 80Plus Platinum  |~| Boot: Intel 660p 2TB NVMe |~| Storage: 2X4TB HDD 7200rpm Seagate Iron Wolf + 2X2TB SSD SanDisk Ultra |~| Case: Cooler Master Case Pro 3 |~| Display: Acer Predator X34 3440x1440p100hz |~| OS: Windows 10 Pro.
Personal Use Rig:
CPU: Intel Core i9 9900 @4.75ghz |~| Cooling: beQuiet! Shadow Rock Slim |~| MOBO: Gigabyte Z390M Gaming mATX|~| RAM: 16gb DDR4 3400mhzCL15 Viper Steel |~| GPU: nVidia Founders Edition RTX 2080 Ti |~| PSU: beQuiet! Straight Power 11 80Plus Gold  |~|  Boot:  Intel 660p 2TB NVMe |~| Storage: 2x2TB SanDisk SSD Ultra 3D |~| Case: Cooler Master Case Pro 3 |~| Display: Viotek GN34CB 3440x1440p100hz |~| OS: Windows 10 Pro.
HTPC / "Console of the house":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
If you just want a lot of SATA ports, then any ATX mobo will do with the help of PCIe to SATA expansion cards.
If you also need performance, then I'd suggest Ryzen 7 / Ryzen Threadripper.
X299 is very good, but expensive as [profanity]
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
46 minutes ago, zpoison said:
Hi guys,
Which boards? My Rampage V Extreme is doing great.
Probably the lesser tier boards. Or silly users killing theirs with stupid settings.
X99 Deluxe user here. Never had a problem in the 2 years I've used it.
