How much can you pull on the core clock? It seems that some laptop 1050s are limited to 135MHz offset, while some could go further.
Desktop benching:
22 minutes ago, NSDUO said:
25% offset
Can you enable voltage monitoring and control inside afterburner settings?
I haven't seen clock speed offset being shown as % inside afterburner. Probably because my experience is with an 970M. Anyway try apply +10% offset to the core clock first, and run a game benchmark (if your games have that). Then reset the core clock, apply +10% offset on the memory and run game benchmark again. Which one gives better frame rates?
Desktop benching:
I have voltage monitoring and control enabled, i still cant control voltage for some reason.
it's normal. I don't know whether this laptop supports it, but most (but not all) laptops don't support GPU voltage control. You can see it, but not control it.
Desktop benching:
