Ok, So here an a week or so, I might upgrade my monitor. I currently have 3 LG potato displays. Hdmi/vga/Dvi only, and cheap build quality.
So, I want an upgrade. My budget is ~1000 USD. I plan to do Light, non competitive gaming(Minecraft, Rocket League, KSP) and Video editing w/ minor color correction.
I want a 1440p monitor because 1080p looks like a rotten tomato.
I would really like an Ultrawide or two.
Having 1 ultrawide and two smaller 1080p monitors also works, I just want everything to look good.
Build quality Is also important.
Ask me any questions.
Main Laptop: Google Pixelbook
Dev mode w/ Cross Enabled
PC: Ryzen 7
1700x / 32GB 2667 / GTX 1080 / 1.5 TB of SSDs / 1TB of HDDs
Monitor: AW3418DW Ultrawide
120hz / 3440x1440 / RGB / Amazonbasics Dual Monitor Arm
2nd Monitor: Dell U2515hx
25 inches / 1440p / Portrait / Amazonbasics Dual Monitor Arm
https://linustechtips.com/topic/806717-monitor-upgrade-help/
What is the meaning of life? JK. What are you editing? Youtube videos? Or you entering professional video editing?
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134487
Youtube definitively, Thats unless my channel blows up tonight lol.
PC: Ryzen 7
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134492
PC: Ryzen 7
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134511
Just now, Microsoft Master said:
I'll find you a curved monitor but do you like the side monitors??
I guess, but i could also use my current 24 inch monitors until I can get Better ones for the sides
PC: Ryzen 7
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134519
If can afford one, Dell's higher-end monitors are highly recommended because of their color accuracy and the high quality of their build quality (PSA The sale ends in 3 hours so if you want it, you need to buy it now):
https://www.newegg.com/Product/Product.aspx?Item=N82E16824260239&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I had to cheap out on this to try and stay close to the budget:
https://www.newegg.com/Product/Product.aspx?Item=N82E16824236465&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Also, not a newegg fanboy but that is just where I found them the cheapest.
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134521
Thats a good idea so you can get a decent starter 1440 for the sides when you eventually, but i recomend getting whatever those tinted glasses are called, they are like $25 at best buy to help stop the eye strain of the two resolutions until you can get 1440p side monitors.
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134522
Here is he main monitor https://www.amazon.com/Acer-Curved-34-inch-UltraWide-Display/dp/B0111MRT90/ref=sr_1_5?s=electronics&ie=UTF8&qid=1499917560&sr=1-5&keywords=ultrawide+curved+1440p
https://linustechtips.com/topic/806717-monitor-upgrade-help/#findComment-10134523
