Hi guys,
i'm in the procces of upgrading my pc i bought a r5 1600 16 gb ddr4 corsair lpx 3000 and an asus b350-m A motherboard
i have installed everything like normal plugged in and it wont work. I see lights on the motherboard so i know its recieving power.
i tried 1 sticj of ram and switching it testing ezch slot but no boot. Help guys what do i do?
specs: gtx 960 4gb msi
r5 1600
asus prime b350m a motherboard
ddr4 16gb lpx corsair 3000
be quiet system power 350 watt
https://linustechtips.com/topic/806485-help-upgraded-pc-and-wont-boot/
This could be an issue that you're not supplying enough power to the CPU
  • CPU
    AMD Ryzen 7 5800X3D
  • Motherboard
    MSI MPG X570S Edge
  • RAM
    32Gb G. Skill F4-3600 DDR4
  • GPU
    MSI Radeon RX 7900 XTX
  • Case
    Some Lian Li Mid-Tower White
  • Storage
     NVMe 970 Evo 500Gb - Boot
  • NVMe WD Black 4Tb - Storage
  • PSU
    1000W EVGA SuperNOVA Gold
  • Cooling
    Noctua NH-U12S
you need a minimum of a 8 connector for the new am4 boards and CPUs
3 minutes ago, Tauwer said:
  • CPU
    AMD Ryzen 7 5800X3D
  • Motherboard
    MSI MPG X570S Edge
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
    Noctua NH-U12S
you'll probably need something with 500w or higher to power your system
  • CPU
    AMD Ryzen 7 5800X3D
  • Motherboard
    MSI MPG X570S Edge
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
    Noctua NH-U12S
