32-bit or 64-bit OS on 4GB RAM
djdelarosa25
I have an old PC lying around and I'm thinking of breathing new life into it by installing Windows 10. It's pretty ancient hardware (Q9550, HD 5450, 4 GB DDR2) and the mobo doesn't support more than 4GB of RAM. Should I install 32-bit or 64-bit W10?
The only reason to use 32 bit is if the CPU doesn't support 64.
Thanks for the feedback! The reason I asked is that I read somewhere that 32-bit is leaner on resources, which will theoretically make your PC run faster, though I'm not so sure about its validity.
If you want to make it run faster delete System32
Lolzy
to get the "most life" you could try linux, however drivers can be a bit annoying.
Personally I'm trying to fix wifi and sound drivers on 2 different computers.
Windows 10 could be resource friendly though. 4 gb is plenty for that OS. I ran 2gb of DDR2 in windows 10, and was using 3ds max. 3ds max recommends 8gb minimum so only within that program it was exceptionally slow, however it was generally usable. (as in lighterweight tasks.)
Agreed, But to add, also if you have a legacy hardware without 64-bit drivers, and that hardware is very expensive to replace, or you use a software that is very costly to update/replace that is coded for 16-bit CPUs (basically, the software of that expensive hardware). 64-bit Windows dropped 16-bit support.
32bit not only limits the RAM but all memory the OS can handle. VRam included.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
What everybody else has said, but also:
On Intel Atom machines, 32 bit Windows will run quite a bit faster, especially older ones, since their 64 bit execution is kinda borked.
If you have 1GB of RAM you should definitely use 32 bit Windows to save on the additional memory space required by 64 bit libraries. 2GB of ram can be a tossup. 32 bit Windows 10 supports Memory Compression the same as 64 bit, so even on Windows 10 it'll "stack" and lower memory usage further. Anything more than 2GB you're best off using 64 bit in most cases.
