Looking for a large phone mount for use with a tripod.
Solved by Hulkbert,
1 minute ago, xDanielxOossiex said:Yeah my phone is 72mm wide and fits perfect in my tripod. I think you'll just have to try some out.
Well good to know, and thanks for the help. Also I think I've found something that might work (if the specs are real and my math is right).
This one goes up to 88mm
https://www.amazon.com/gp/product/B00WFNNNCC
and this one goes up to 101mm
