What exactly is AVX and do I need it?
Solved by Zodiark1593,
AVX is an extension to x86 that allows a (quite drastic) speed up in certain floating point operations. AVX will primarily impact media transcoding where it is used in a home server. As just a streaming box, there will be no impact.
2
resonate ·
Posted in Laptops and Pre-Built Systems0 -
jstrafe ·
Posted in Build Logs2 -
thstudios ·
Posted in Storage Devices0 -
skkler ·
Posted in Cases and Mods3 -
Iggzy ·
Posted in Troubleshooting6
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
