Gaming issue with msi gtx 650ti boost in Sli
Ok I am rather annoyed I have two MSI 650 TI BOOST 2GB running in Sli with them overclock. Also a AMD Phenom II  x6 1055T 2.8ghz OC @ 3.3ghz. And 16gb of Gskill memory. But assassin's creed 4 won't run past 20 frames in dark seaons or close quarter fighting. It will jump to 30 frame sometimes but not much. So do I need to just go for a gtx 770 or is my CPU to old? We're is the bottle necking at. HELP PLEASE this game is the best I ever played and want to be running it on max settings!!
Two low end cards in SLI=terribad.
One higher end card is pretty much always best.
It's probably the drivers, because (apparently) scaling in SLI is good for AC4.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
Probably best to just upgrade your GPU setup. I don't know why you would have went with a 650 SLi anyway.
Turn some settings down in the mean time, like AA and Texture quality.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
I've said this once, and I'll say it again. AC4 is an unoptimized piece of garbage. Stop buying games day one.
Wait for driver updates and patches from Ubisoft, I doubt there's anything you can do to fix this.
This is the most likely problem with AC4, your cards aren't bad.
the Ti Boost isn't low end and two of them perform around where the 670 is.
When was the last time you updated your Nvidia drivers? AC 4 isn't very optimized yet so ofc. your performance will suck.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
I have two 650ti boost because one I got free and always wanted to try out SLI. I haven't downloaded new drivers since battlefield 4 so I will do that today. I know one card is better then sli but this is what I got and these card perform well for every other game I have. So assisan creed 4 needs some help. But the game does look amazing. Thanks for feed back.
 Share
