Screw "stuck" in a screw hole on mobo
Solved by TheRandomness,
That's a standoff, the thing the other screw is screwed in to. Just use some pliers to hold the standoff, and unscrew the screw as you normally would do.
1
14
8
11
6
EzioWar ·
Posted in Operating Systems1 -
4
1
Pryme ·
Posted in Power Supplies8
