Corsair Air 540 Best Fan placement
I would keep the way it is - 2 x 140 intake in the front, 2 x 120 up top as exhaust, and 1 x 140 rear exhaust. I think that set up is ideal for minimum noise level. Plus, the way the case is designed, a standard set up like yours is good enough to flush warm air out of the system.
Jar3av123 ·
GOATWD ·
Posted in Peripherals0 -
1
AdamWarlock ·
Posted in Laptops and Pre-Built Systems5 -
Eamonc26 ·
Posted in New Builds and Planning3 -
1
WaitforAmpere? ·
Posted in Audio2 -
Benb112 ·
Posted in Troubleshooting6 -
LukeCorbishley ·
Posted in CPUs, Motherboards, and Memory41 -
pandaarts ·
Posted in Console Gaming7
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
