I have a 5+ year old HDD and I am looking to clone the OS (and some other info) onto a new WD SSD. I have tried AOMEI, EaseUS, Acronis WD, Macrium and all have failed with errors regarding the drive. I have defragged the disk and run CCleaner registry repair. I continue to face "$i30" wrong index notices. I managed to "succeed" with Acronis but when booting into the SSD, the lock screen flashes and I am unable to log in. I have done this multiple times and wiped the SSD multiple times. I have run chkdsk /r /x /f. I am currently running WD Data Lifeguard Diagnostics but the Quick Test estimated to take 2 minutes is taking more than 45 as of this message. I strongly suspect the drive is damaged BUT I continue to boot into it and enjoy full operability on Windows, albeit quite slowly. I just want to evacuate my OS and data and Windows settings and themes onto the SSD and I won't have to think about this HDD anymore. Please help, I have tried so many things...
https://linustechtips.com/topic/792756-need-help-cloning-hdd-onto-ssd/
What OS?
What does SMART data say about the two drives?
I would recommend doing a fresh install since the hard drive could be damaged.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Copy all the data to an external USB drive, and then do a clean install of Windows on the SSD. Then move everything over.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
I would highly recommend not cloning the drive. You would be much better off pulling the Windows license off the HDD and then create a fresh Windows install on the SSD. It's more of a pain, but you would be better off starting fresh.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Try to backup it to an image on a different drive and restore it on the SSD. Might work.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
You have 2 ways of doing this, 1. you can clone your valuble data onto an external drive then reinstall windows on the new drive. or 2. you can use software like AOMEI Partition Assistant to clone your OS drive to another installed drive
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
9 hours ago, Algalon said:
If the HDD is so screwed, how could I continue to boot off of it and use it fine right now?
probably not for long. but if it isnt, it could just be corruption in windows, so cloning it will only bring the problems to the ssd. you could use clonezilla. works everytime.
first boot system from windows disc to cmd prompt
then run chkdsk "driveletter": /r
do this both drives
when that finished
xcopy *.* "sourcedrive": "destinationdrive": /s /e /k /h /x /y and if overnetwork /z
make sure destination drive has already been formated with bootable permissions set before you start the copy process
Wow, that is annoying. Failed with so many popular cloning software. Have you ever tried clone to another disk or test the WD SSD on another computer? Anyway, clean install would be my first choice. As to the 200GB data, make a backup image for them using AOMEI Backupper or the like. The process might be shorter.
If there are applications you don't want to reinstall, how about making a backup image for the entire hard drive and restore it to the new SSD? This methods requires a bootable device. A bootable device with backup software installed also allows you to backup hard drive without booting Windows.
Good luck.
