Fixed computer and it will power but won't show on screen...
So the other day my computer stoped working due to a dead power supply. I did a lot of troubleshooting and found the power supply overheated and broke so I ordered a new one while my other was in the rma process. So I pluggex everything in in the new power supply and I turned it on and it worked. However when I plugged it all into my setup and I turned it on the monitor did not pick up anything and the power button on my led keyboard did not turn on. When I turned my monitor on it did the scanning for devices and went to hdmi, but it just kept flickering. So I plugged all of my stuff in different ports (after I turned it off), and tried again. Same thing happened. I probably could have accidentally unplugged my dad from power or unplugged the data sata connector somehow but I wanted some advise from ltt because I do not know how to proceed with troubleshooting.
Specs:
Cup: FX8350
GPU: AMD RX480 Sapphire
PSU: EVGA W1 500
SSD: PNY 240gb
Monitor: Samsung 27" Curved(all I know)
Have you got all the power cables in and in the right place? 20/24/28 pin main mobo power, 4/8 cpu power, sata power for drives etc
Desktop benching:
I am pretty sure everything is plugged in
Second thing are pins on the mobo connected to the switches on the case. Are they still in place? They aren't fixed tightly, so it's possible to knock them off with a light pull
Desktop benching:
