HELP!! I want to build a machine!
Go to solution Solved by Zando_,
1 minute ago, IntelBeastboy said:
Hopefully.
How'd I done?
https://pcpartpicker.com/list/3KJbHN
Good, though I've heard the cooler is terrible on the Armour OC cards.
Hello,
First off I want to thank you for your help up front!
I would like to build a PC and be able to play these games below.  I don't want to spend more than $800 on a box, $200 on a monitor if I have to.  If possible I want to be able to record and to expand my hardware down the line.  I will be reusing my Kingston V300 240GB SSD for Windows but would like a data drive.  I own windows as well.
Games are:
  • Forza Horizon 3
  • GTA V
  • American and Euro Truck Sims
  • Minecraft w/ shaders
  • Tekkit Classic
  • Battlefield 1
Step one, I'm off to PCPartPicker.
Step two, you're IntelBeastBoy, yet have an AMD slogan as an avatar?
Main PC
CPU: i3 12100F
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz Team Group T-CREATE DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2x 1TB MX500
PSU: EVGA 850W GM
Case & Fans: Fractal Design Node 304 - 2x Noctua NF-A9 + Noctua NF-A15
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Here (assuming you're in the US):
PCPartPicker part list: https://pcpartpicker.com/list/8W277h
Price breakdown by merchant: https://pcpartpicker.com/list/8W277h/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($174.88 @ OutletPC)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard  ($96.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Sapphire - Radeon RX 580 4GB PULSE Video Card  ($231.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $814.16
Generated by PCPartPicker 2017-06-12 13:35 EDT-0400
Main PC
CPU: i3 12100F
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
  Hide contents
Total: $814.16
except that 580 is out of stock , and finding one at that price is not likely.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
3 minutes ago, IntelBeastboy said:
Hello,
Games are:
  • Forza Horizon 3
  • GTA V
  • Tekkit Classic
  • Battlefield 1
https://pcpartpicker.com/list/cFwhwV
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
Then the OP can get a 1060 6GB:
PCPartPicker part list: https://pcpartpicker.com/list/XQjpkT
Price breakdown by merchant: https://pcpartpicker.com/list/XQjpkT/by_merchant/
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SSC GAMING Video Card  ($259.99 @ Amazon)
Total: $842.16
Generated by PCPartPicker 2017-06-12 13:40 EDT-0400
Main PC
CPU: i3 12100F
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
USD for currency get 580 if possible I'm not buying until August. Just researching
  Reveal hidden contents
Total: $842.16
Irony.
If you can stretch your budget a bit ( 25$ ) , you can get this:
PCPartPicker part list: https://pcpartpicker.com/list/jz8M7h
Price breakdown by merchant: https://pcpartpicker.com/list/jz8M7h/by_merchant/
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($158.69 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($83.89 @ OutletPC)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Video Card: MSI - GeForce GTX 1070 8GB Video Card  ($366.33 @ Amazon)
Case: Corsair - 200R ATX Mid Tower Case  ($41.99 @ Newegg)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($36.88 @ OutletPC)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($182.99 @ B&H)
Total: $1024.20
Generated by PCPartPicker 2017-06-12 13:46 EDT-0400
Then see my first list, it's the same thing with an RX580. And good thing you can wait, hopefully the mining craze will have died by August.
Main PC
CPU: i3 12100F
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
Hopefully.
How'd I done?
Main PC
CPU: i3 12100F
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
Okay, I'll swap it when parts come back in stock.
Hopefully the strix card price drops signifcantly
Just now, nerdslayer1 said:
looks good
Could this record some of those games?
yup, easily.
its not though... I mean, its not as good as other coolers on more premium cards, sure.... but its not "terrible" by any means.
1 hour ago, IntelBeastboy said:
Games are:
  • Forza Horizon 3
  • GTA V
  • Tekkit Classic
  • Battlefield 1
Based on your game list this is the sort of build you should be after: https://pcpartpicker.com/list/tFgtFd
that build is similar in many regards to your earlier mentioned one, and your earlier one is fine, although i would definitely recommend a motherboard which doesn't skimp out on the features. the PC MATE board in my build there comes with 7.1 audio, USB C, and stuff like that which your Asus board lacks. Also for your choice of monitor it would probably be a good idea to find something with freesync if you're getting an AMD card. you may or may not make use of it, but its a good feature to have which doesn't really cost anything.
Update: Build completed with suggested monitor added in: https://pcpartpicker.com/list/q4JfZ8
there are certainly cheaper freesync panels out there.... but this one is IPS, 27", curved, and has a good response time. its up to you whether or not you feel those are good features to invest in. GL with the build! :D
Thank you, I'll swap those parts in my list.
I went with this LG instead I like it better.
https://pcpartpicker.com/product/ZqyxFT/lg-22mp68vq-p-215-1920x1080-60hz-monitor-22mp68vq-p
