Removing soft tubes from compression fittings
Best bet is unscrew the compression, and then to pinch at the top of the fitting and twist
Wait are you Nicky V's cousin? But I would try to tip it away from the GPU but is it full of coolant?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Ok, thanks to you both. I'll try removing the fitting. Otherwise, I'll take the GPU out.
No coolant. Just installing.
Not a cousin or even aware of a Nicky V. :-)
Oh then just unscrew the barb fitting but you don't know about Nicky V
