IBM innovation allows for 5nm process silicon
zxsq
https://www.wired.com/2017/06/ibm-silicon-nanosheets-transistors/
This will help break the 7nm lower limit on the FinFET process, so dies can continue getting smaller for at least a few more processor generations.
IBM Research scientist Nicolas Loubet holds a wafer of chips with 5nm silicon nanosheet transistors manufactured using an industry-first process that can deliver 40 percent performance enhancement at fixed power, or 75 percent power savings at matched performance.IBM Research scientist Nicolas Loubet holds a wafer of chips with 5nm silicon nanosheet transistors manufactured using an industry-first process that can deliver 40 percent performance enhancement at fixed power, or 75 percent power savings at matched performance.CONNIE ZHOU
“The world’s sitting on this stuff, artificial intelligence, self-driving cars. They’re all highly dependent on more efficient computing power. That only comes from this type of technology,” says Hutcheson. “Without this, we stop.”
Thread locked since it is a repost.  Please be sure to check for any similar articles before posting
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Guest
