Is it the exact same remote or is it different for the wireless connection or sizing of the remote?
I want to get a spare Wii remote plus and a nunchuck and I found one but it's from Japan.  I just don't want to buy it and find it doesn't work.
Should use the same protocol. I've never tried though.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Are you referring to the Wii or the Wii U? If you are referring to the original wii then yes that will work, confirmed.
25 minutes ago, Dan Castellaneta said:
Yes, you can use Japanese Wii remotes with an American Wii U. They aren't region locked.
I was concerned they might use different wireless frequencies or something.
Wii U is what I'd use it with but so far as I know both the Wii and Wii U use the same remotes.
Nah, from what I remember it's basically a Bluetooth variant, so it really couldn't differ from each other.
Different countries might have different rules on electronic devices and signals they emit so I wanted to be sure.
I could get a NA Wiimote plus for about the same as what it seems I could get a Japanese set that includes a nunchuck so I'd rather get the better deal but checking first seemed wise.    Kind of hard to return items coming from foreign countries.  ?
wiimotes are bone stock bluetooth, you can pair them with your PC if you want, it'll even show up as a wiimote, you just wont be able to do anything with it without software specificly made to capture wiimote inputs.
Using it to play Skyward Sword on my Wii U would be sufficient.  ?
Controllers for the most part (I've yet to see any from any recent console) be region locked.
I've been stationed in Japan and have used both US and Japanese Wiimotes with my US Wii and Dual Shock 3's with both a US and Japanese PS3.
Good to know.
You're in the military?  Or were?   Do you mind if I ask what branch?
6 minutes ago, linkboy said:
I was (getting out at the end of the month). Did 11 years in the Air Force.
Cool.  I thought about the Air Force at one point but wasn't sure I was cut out for it.
Little off topic (I'll allow it though this is my topic. lol) but thank you for your service.  ?
Not everyone appreciates people who served so I feel it's important to show some gratitude for your serving in the Air Force.  Best branch IMO.  ?
