2 minutes ago, WalkerOfSkys said:
Hi guys,
I want to overclock my I7 7700K, and would like to water cool it.
Do you guys have any suggestions for Water coolers?
Other PC specs:
GTX 1080Ti
16GB DDR4
Z270H
Thanks in advance,
Luke
you can't overclock that CPu
cound't see the k
AIO or custom
My life
https://linustechtips.com/topic/787581-water-cooler-for-i7-7700/#findComment-9922927
1 minute ago, WalkerOfSkys said:
Hi guys,
Other PC specs:
GTX 1080Ti
16GB DDR4
Z270H
Thanks in advance,
Luke
I recommend the NZXT Kraken X62. I have it working with my 6850K and it stays cool even when overclocked.  It has RGB but I have it disabled, but it is always there if I want to use it.
https://linustechtips.com/topic/787581-water-cooler-for-i7-7700/#findComment-9922934
Hi guys,
Other PC specs:
GTX 1080Ti
16GB DDR4
Z270H
Thanks in advance,
Luke
PS It's an enthousiast build, so price shouldnt really matter
I have a kraken x61 and it's fantastic. Get the newer version (Kraken x62) of course tho
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/787581-water-cooler-for-i7-7700/#findComment-9922944
If you wanna throw money at it go custom and add the GPU to the loop also. Watercooled Pascal will maintain higher boost clocks than air.
As a guide go with 12mm tubing and I would say Rigid from the off, watch some vids and buy twice the amount of tubing to allow for errors.
Basic loop will need 2 fittings per component in the loop + a couple of extras for drains etc.
So a loop for you would be like
Reservoir
Pump (or a combo)
360mm + 240mm radiator if your case allows
CPU Block
GPU Block
5x High Static Pressure 120mm fans (Ek Varder, Thermaltake Riing 12, Noctua etc)
A loop like this would need like 14 fittings.
90 and 45 degree can also help with looks and make tube routing easier
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/787581-water-cooler-for-i7-7700/#findComment-9923093
